Old 07-01-2004, 06:14 PM   #1
BuckeyeBlazer
BuckeyeBlazer's Avatar
Need some advice
I am new to the board and recently purchased a 1972 CST Blazer 4X4
It has quite a bit off underbody rust (rockers, rocker boxes, tub and bed floor) and needs some work. I starting to think I made the wrong decision
I am not going to do any work to it right now, but I recently found 2 wheel drive rust free rolling chassis up in Michigan. I'm going up to Michigan this weekend to look at it.
So this is where i need some advice. He says it is rust free and straight. The underbody and interior have been blasted and coated. (underbody looks clean)
No engine, tranny or transfer case. It has been converted from 4wd to 2wd.
Interior is really rough.
Single wall top.
GMC front clip and tailgate.
He is asking $3500...$3000 without the front clip which I don't need.
How much do you all think it is worth?????
BuckeyeBlazer is offline   Reply With Quote
Old 07-01-2004, 06:47 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
With no interior or engine and since it is a converted 4wd, I would guess in the $1,500-2,500 range, depending on how much is there. You would basically be buying a tub.
Do you know how the frame was converted to 2wd? Did they keep the leaf springs in the back or go to the trailing arm suspension? Are you thinking about doing a body swap and putting that body on the 4wd frame or fixing up the 2wd? What was it coated with after blasting?
This is just my guess and actual prices may vary in your area.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-01-2004, 09:20 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I Second The Bouncer, U R Mainly Gettin A Tub, It Is Up To U
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-02-2004, 02:07 AM   #4
BuckeyeBlazer
The underbody was coated with POR15 after it was blasted. I believe it has the original leaf spring still on the back. I attached some photos of the the tub and underbody.
I am undecided on what I would do with it....I would either but the rust free body on my 4x4 chassis or......through my front axle and transfer case back under this new chassis and convert it back to 4 wheel drive. I am not interested in a 2wd blazer. I guess I would just try to part out what ever is remaining.
Old 07-02-2004, 02:22 AM   #5
BuckeyeBlazer
Sorry... been double posting the pics....still learning how to use this message board thing.
Old 07-02-2004, 05:10 AM   #6
vtblazer
vtblazer's Avatar
Tub
Passenger side outer rocker/front door pillar looks kinda interesting...is that a repair? Are the windshield and gasket included? The windshield can be tough to get out with out cutting the gasket...or breaking the glass
Check over the firewall and cowl sides for rust evidence too.
Wanna sell the single wall top if you get it?
vtblazer is offline   Reply With Quote
Old 07-02-2004, 05:27 AM   #7
HatGuy
HatGuy's Avatar
If that is the original seat in the
picture it looks like a rare option
called "Highlander". Looks like the
gray plaid. Mine is blue plaid.It was
made in red/orange and green also.
If you don't want the seat old covers
I will take thaem off your hands for
the plaid inserts.
Joe
http://www.petersbros.com/BLAZER/index.html
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
