07-02-2004, 02:12 AM | #1 |
Embrace the Redneck
for you guys who have put a 350 in a 68
When i get ready to mount that 350 in the CE what motor mounts will i need?
The motor mounts for the 80 to 85 motor or the 68 motormounts. Mind you i'v got the orgional towers already in the truck, hince the CE. Or will i need to have some mounts fabed up for me. thanks sswj
'01 Camaro Son, you just can't get there from here... |
07-02-2004, 05:50 AM | #2 |
I bought a GM crate motor 350 in '99 for my '71 Jimmy. It dropped right in, but I did get a crate motor from the dealer for my vintage.
(My '68s got an L6, but the frame doesn't look much different otherwise.)
07-02-2004, 06:52 AM | #3 |
blood type; Retumbo
use the '68 mounts. they will bolt right up to engine. later ones will fit engine but not the towers. one word of caution, the '68 mounts & towers will not fit any stock manifolds other than thr ram horn style. if you are using headers disregard the last statement.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
07-02-2004, 08:20 AM | #4 |
Embrace the Redneck
but when i go to the parts store which mounts do i need to ask for?
sswj
07-02-2004, 08:40 AM | #5 |
Fabricate till you "puke"
The I 6 & the sb use the same eng mounts( same pn). The stands are different, as far as placement front to rear on the eng, but the sb will mount on the i 6 stands. if you are running a stick, with the bell crossmember, i would use the i 6 stands.....to swap to the sb stands, you will also need to swap the bell crossmember. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-02-2004, 11:33 AM | #6 |
Watch out for your cornhole !
Ask for 68 mounts at the parts store. They usually run 6 to 11 bucks each.
