07-02-2004, 11:56 PM | #1 |
Installing blue dots
i have the holes drilled in my covers but was wondering what to use to hold the blue dot in place?? just use something like crazy glue??
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
07-03-2004, 12:04 AM | #2 |
I thought that they snap in place.
07-03-2004, 12:12 AM | #3 |
they have 4 tabs on them that look like you should just bend em out after they are inside the lens
i wanna make sure they don't fall out
07-03-2004, 03:17 AM | #4 |
Try some clear silicone around the inside? That would also help to seal against moisture.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
07-03-2004, 08:59 AM | #5 |
last set i installed i just twisted the tabs,instead of just bending them that way you got something to hold in the lens in the holding ring and the ring to the lens.
good luck jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
07-03-2004, 03:16 AM | #6 |
mine had the four tabs and the instructions said to just bend them out to hold the dots in. they seem to be pretty secure like that and they are still in the lens. so it must work pretty good. good luck.
'67 c10 350/th350 |
07-03-2004, 09:05 AM | #7 |
PROJECT 7DEUCE
When I put mine in I bent 2 tab's over the glass dot and bent the other 2 outward over the plastic lense..
07-03-2004, 10:06 AM | #8 | |
10-24-2004, 11:48 PM | #9 |
wth are blue dots?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
10-25-2004, 12:52 AM | #10 | |
72 C10 Suburban 90 S10 57 F100 (2) 67 Mustang (2) 69 Torino GT 00 Mustang GT Conv. Last edited by sub4rvr; 10-25-2004 at 12:55 AM. |
10-25-2004, 12:55 AM | #11 |
Got Light Emitting Diode?
and arnt they illegal??? not that i care, i am sure i could get a ticket for some of the stuff i have done to my truck
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
10-25-2004, 01:01 AM | #12 |
I am with Jamie72 I have installed them in this way many times!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-25-2004, 04:23 AM | #13 |
its all about the +6 inches
Yeah, plenty of states have made them illegal.
You do't want to use crazy glue.super glue on plastic lenses, it'll fog them up REAL bad. |
10-25-2004, 12:29 PM | #14 |
I PUT THEM IN THE SAME WAY AS JAMIE72 & DJRACER DID, BY TWISTING THEM. I ALSO PUT A BEAD OF JB WELD AROUND THEM. THEY'VE BEEN HOLDING UP IN MY BLAZER FOR MORE THAN 8 YEARS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
10-25-2004, 03:41 PM | #15 |
does anyone have any night pictures with the lights on?
10-25-2004, 04:39 PM | #16 | |
Here you go. Not a great picture but you can see them in there. ignore the one purple and one green light
1972 Chevy C/10 350/200r4 |
10-25-2004, 03:43 PM | #17 |
When I did the install, I bent the tabs and put a couple small dabs of contact cement on the sides of the bezel. Worked great!! and they looks very cool I don't have any pics of what they look like with the lights on
10-25-2004, 07:04 PM | #18 |
Any rear facing light other than red is illegal.
10-25-2004, 07:18 PM | #19 | |
10-25-2004, 09:44 PM | #20 | |
Here in Ohio, motor Cycles can have the blue dots. In Nevada (I think it's nevada) they reversed the no blue dot law a few years ago, and you can run them on anything. |
10-25-2004, 09:50 PM | #21 |
10/30/19
Hey canadianchevy72,do I see maple leaves in your tail lights too?Or am I just seeing things from looking too hard?
10-25-2004, 10:22 PM | #22 | |
i see them too...i think
10-25-2004, 09:51 PM | #23 |
The thing is I think most cops look for guys with imports now, so they leave us alone. Most of our trucks are driven by older guys
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
10-25-2004, 10:00 PM | #24 |
Half a bubble off!
There is the alternative of Bowtie Red Dots.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
10-25-2004, 11:41 PM | #25 |
I dont care if you been using them for fifty years A blue rearward facing light is illegal I have the 175 dollar ticket to prove it.
I thought about how some mini trucks have orange turn signals as well as many cars But i know for a fact that blue is I used to have blue reverse lights and They came on by a switch wich i sometimes forgot to turn off. |
