Old 07-03-2004, 08:28 AM   #1
Daves72'GMC
How good are front end urethane bushings?
What are the pros and cons on urethane front end bushings and where can I get them for my 72' 3/4 GMC?Thank you
Daves72'GMC is offline   Reply With Quote
Old 07-03-2004, 12:01 PM   #2
gonebad2
Merciless Butcher
gonebad2's Avatar
Pro: Tighter handling, less body roll......Con: They can be squeeky and annoying. Get the ones that are impregnated with graphite. They are alot quiter. Search the net...I'm sure there are plenty of companies that offer them.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 07-03-2004, 10:41 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your truck uses steel bushings.
The only possible place to use urethane on your trucks front end is the swaybar.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-03-2004, 11:34 PM   #4
junkyardjohn
junkyardjohn's Avatar
TX. IS RIGHT---- THE ONLY PLACE FOR POLY. BUSHINGS IS THE SWAY BAR, RAD. SUPPORT BUSHINGS, OR CAB BUSHINGS . JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-03-2004, 10:58 PM   #5
7gmc2
7gmc2's Avatar
i have been thinking down that same road myself , and chevy duty seems to offer alot of urethane parts for these model trucks. check them out!
7gmc2 is offline   Reply With Quote
Old 07-03-2004, 11:04 PM   #6
Tx Firefighter
Old 07-04-2004, 12:08 AM   #7
krue
Designated A-hole!
krue's Avatar
Would that be a good reason to go with a 73 and up front suspension?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-04-2004, 08:19 AM   #8
Tx Firefighter
Why do people use urethane bushings? Because they are stiffer than stock rubber and don't allow flexing. Those steel bushings already do that. Believe me, the steel will be lots firmer than urethane.
Save your money for something else. Everytime I've ever used urethane stuff (mini trucks and street rods), I've been sorry I did. The car always develops more vibration in it. The rubber stuff does good insulating road vibration from you.
Old 07-04-2004, 10:00 AM   #9
krue
Designated A-hole!
krue's Avatar
I wasn't talking about using poly bushings, I was just wondering if you wore the steel bushing out, how would you replace it?
www.daveramsey.com
Old 07-04-2004, 10:36 AM   #10
64fleetside
Just replaced them on mine, they simply unscrew with an impact after removing a-arms. Mine had been installed improperly, there is a tit on crossmember that is supposed to fit into the bushing shaft to locate it properly. I guess PO didn't pay attention. Brian
64fleetside is offline   Reply With Quote
Old 07-04-2004, 11:43 AM   #11
junkyardjohn
I HAVE REPLACED THEM ON A FEW TRUCKS, & I HAVE ALWAYS GOT A UPPER OR LOWER CONTROL ARM SHAFT KIT. IT COMES WITH THE SHAFT & THE CAPS OR BUSHINGS. THE ONLY RUBBER ON THEN WAS THE SEAL TO HOLD THE GREASE IN. THEY'RE NOT TUFF TO REPLACE, BUT IT IS A GOOD TIME TO CONCIDER REPLACING YOUR BALLJOINTS. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 07-04-2004, 12:41 PM   #12
krue
Designated A-hole!
krue's Avatar
Thanks, that's what I wanted to know.
www.daveramsey.com
Old 07-04-2004, 08:15 PM   #13
Ruckus
I'm working on rebuilding my frontend right now. Does anyone know offhand what size the ends of the upper/lower bushings are? Thanks
1971 GMC LWB 350/350--SOLD
1970 Chevy LWB 350/350--SOLD
2000 VW VR6!
Ruckus is offline   Reply With Quote
