![]() Join Date: Nov 2002
speedo stuff for 67cst
here you go. don't know if you need plastic gears, but here's a few I have in case you're changing your tire/wheel size.
i love summertime
will that work with my th400?, im running 60 series tires but im not too concerned about the speedo being off a bit...im just heading out the door to go fishing for the afternoon, so ill get back to you tonight, but if that will work with my truck then im sure ill take it...
check pm
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
350 or 400---tranny
does anybody know if the part where the speedo connects to the tranny differ on a turbo 350 to a turbo 400?
thanks..... |
i love summertime
ttt-------------anyone?
i love summertime
one more bump! come on guys...someone must know if the speedo cables are the same on th350s and 400s...
thanks in advance
speedo cables
Derek,
The cables are the same. The only problem I have seen is the variety of lengths in cables out there. Help! Product line of MotorMite offers several different cables but you need to know th approx. length of the one you have before hand. Any parts store should be able to get you a cable, but be sure to lube it good so that it does not rattle and twist. If you get some rubing alcohol and graphite power, create a solution and put it a spray bottle. The alcohol will act as the carrier for the graphite and the alcohol will evaporate leaving the graphite as the lube for the cable. |
i love summertime
thanks harold
