Old 07-04-2004, 06:45 PM   #1
kickinasphalt
kickinasphalt's Avatar
WOOHOO!!! The lift install/axle swap is done on the 72!!!
Thursday evening I started the process of swapping axles from my 71 into the 72 and installing a 6" Tuff Country EZ-Ride lift in the 72 at the same time. Worked for about 5 hours that night and a good 10 hours the next (half was by myself and I'm not real fast). Just installing the lift would have been pretty easy but have to disconnect everything from both to get the axles out took a while. Plus it didn't help that the 71 was so rusty it took a 7 foot cheater bar to break every nut on the rear u-bolts loose. For tires/rims I went with Pro-Comp Mud Terrain 35x12.5x15 on Eagle Alloy 058 15x10 rims. I found they bairly fit upfront I since the caliper wore a little line into inside of the rim. A few minutes with the grinder on the corner of the caliper fixed that problem. Over all I'm very pleased with the results and the pickup looks badass I will have some pics soon.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 07-04-2004, 09:44 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Good job, but where are the pics? How's it drive? You happy with the lift?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-06-2004, 12:32 PM   #3
Yukon Jack
Yukon Jack's Avatar
That is a lot faster than when I did my first lift. Will be eager to see some pics of your truck.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-10-2004, 02:40 PM   #4
frost89434
frost89434's Avatar
We need PICS !!!!!!!
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
