Booster vacuum hose to manifold
Can you guys help and post a few pictures of the brake booster hose connection to the intake or carb.
I have an orig 307 2bbl. There is a plug cap screwed on top of the intake. it is behind the carb on the passenger side. I think i might have to take the plug cap off and put a plug with a hose connection, but i'm not sure. Thanks for the help. |
"Ochre Ogre"
that is the usual place. You will also find some carbs with a vac location in the base plate of the carb on the back side.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
I will be glad...
to run out to the garage and take some digital pictures of what you need, but I'm too computer-unsavy to post the pics. If I can send them to someone who can post them, I'll be glad to help. The BURB engine is rebuilt with original 307 / 2 bbl and all the original hoses, routing, connections,etc.
7T1BURB |
While we are on this subject. I just got a booster package in the mail from Jason and was wondering, can I tee it into the vacuum line going to the PCV valve or should I run it to the plug on the side of the intake manifold near the base of the carb.. Trucks a 72 C-10 with a I-6 250. Thanks, Mike
337, Don't mean to hijack your thread! ![]()
1972 C-10 LWB (son's) work in progress 1998 Dodge 2500 12V Cummins Diesel 2004 Road King |
Here is a pic, hopefully you can see the vacuum "tree" that screws into the intake manifold where the vacuum line for the booster connects to.
The PCV hose should connect to the vacuum source on the base of the carburetor. Jim |
Is this it?
Is what i circled the tree, correct?
That looks like where the plug cap is on my intake. Now i just have to go and buy the tree. 7t1burb if you want to send to me...i'll post thanks. leemp337@grandecom.net Thanks for the help!!! Last edited by 337; 07-08-2004 at 12:39 AM. Reason: edit |
You have circled the "tree". Here is a link to Paragon as they have a great selection of manifold vacuum fittings.
Jim http://www.corvette-paragon.com/ |
Old Skool Club
![]() Join Date: Jun 2001
Someone correct me if I am wrong, but PCV hose and the hose to the brake booster should both be manifold vacuum. The higher vacuum volume is what you need to properly operate those systems. The ported vacuum is for the distributor advance and the modulator on the transmission, and is lower volume.
When I installed an Edelbrock Performer intake, I couldn't use the Tee that was on the old intake. I went through some adapters and got the vacuum to the booster, and to the modulator. The Q-Jet (Edelbrock 1901) had ports for the timed vacuum that the distributor needs. Everything works well.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
pictures from 7t1burb stock 307 w/2bbl
Hope these picture help someone else...they sure help me. thanks for all the info and pics.
I have POWER!!!!!
I almost went thru the windshield on the test drive today!!!! No need for disk brakes. The drums and the booster are so far the best upgrade for the buck. Next is power steering. Thanks for all y'alls help. |
Where Am I ? How did I get Here ? ![]() 1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact . |
