Old 07-09-2004, 12:31 AM   #1
sam's 72
Tranny lines ( what size )
I am wanting to order some fittings for my tranny lines. I am out at work tonight, and don't have the lines in front of me. I would like to know what size the fittings are that screw into the tranny, and what size is the fittings that screw into to radiator. Can not remember if they are 3/8 NPT or 1/2 NPT. What I am going to do is run areoequiped hoses from tranny to radator, I already have the hose, just need to know what the fitting size is. This is a 700r4, before I pulled my engine out, I had a th350. The stock lines fit perfect to the 700r4. Can some one help me out tonight with this. would like to get the order in tonight.
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 07-09-2004, 01:34 AM   #2
1972C10
1972C10's Avatar
3/8
1972C10 is offline   Reply With Quote
Old 07-09-2004, 02:04 AM   #3
krue
Designated A-hole!
krue's Avatar
I just replaced the lines on my Th350 and used 5/16 brake line. The way I bent mine a 5ft piece wit great for the top line and was about a foot too long for the bottom line.
Good luck with it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-09-2004, 07:26 AM   #4
Bowtie67
Bowtie67's Avatar
I believe mine where 3/8, I also used russel fittings and then made up my own lines using braided lines with the russel fittings so that they can be eaily taken on and off. I also made out of aluminum a junction block that mounted to the frame so if I have to pull the trans out I can just disconnect the 2 lines right there and be done with it in about 2 minutes.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 07-09-2004, 09:59 AM   #5
JimKshortstep4x4
Smile
Original transmission cooler lines are 5/16".
Jim
Old 07-10-2004, 03:03 AM   #6
1972C10
1972C10's Avatar
He was talking about the cooler line fitting ports. On the side of the trans case itself
Old 07-10-2004, 03:12 AM   #7
sam's 72
I am talking about the fitting ports on the tranny, and the fitting ports on the radaitor. I don't really need the line size. Planning on running 3/8" lines. I still need this info. So is the fitting ports 3/8" npt on tranny and radaitor. Or is it 1/4" on tranny and radaitor? I did not have time to go by the shop where my truck is at today to check it out. I have it at a friend of mine shop.
Sam
72 LWB chevy truck.
Pasadena, Texas
Old 07-10-2004, 03:15 AM   #8
1972C10
1972C10's Avatar
are you talking about the flare adaptor size? its a 5/16 flare nut they make adaptors to go from male flare to threads ..
What kinda lines are you putting back on it?
Old 07-10-2004, 03:38 AM   #9
sam's 72
I have some socketless Aeroquip hose left over from plumbing up my fuel line. So, I am going to use this for my tranny lines. I need to know what size are the fittings that screw into the radaitor. I need to know what size the fittings are that screw into the tranny. Planning on buying either russell fittings or Aeroquip fittings for this. So I need to know what size they are. They will either be 3/8" or 1/4". Am I missing something here?
Sam
72 LWB chevy truck.
Pasadena, Texas
Old 07-10-2004, 05:15 AM   #10
krue
Designated A-hole!
krue's Avatar
The radiator threads I believe are 5/8 fine thread. They are not pipe threads, they aren't deep enough. If you want to know exactly what they are look at the fitting on the end of a piece of 5/16 brake line at your local parts store.
www.daveramsey.com
Old 07-10-2004, 07:31 AM   #11
JimKshortstep4x4
Smile
The radiator female fitting is a 5/16 female flare, (threads are 7/16-20 fine thread).
The transmission case is tapped for a 1/2-20 fine thread fitting with a gasket surface machined for sealing the fitting. A gasketed adapter for the 5/16 male flare screws into the transmission.
In the pic, the transmission fitting is on the left and a 5/16 male flare fitting is on the right. If you are adapting a larger line, than an adapter to a 5/16 flare fitting might be the easy way to go.
Jim
