Old 07-10-2004, 10:07 PM   #1
clarissa
1985 GMC Jimmy V8 oxygen sensor
Hi,
Just stumbled here. I need to replace my oxygen sensor and am having trouble locating where the old one is. I see something like it underneath the spark plugs but not sure if this is the temperature sensor. Anyone know?
TIA
clarissa is offline   Reply With Quote
Old 07-10-2004, 11:51 PM   #2
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
what kind of motor do you have?on the 80's 305 motors that had ESC they had a large object in the center of the side of the block-i dont recall what side but that is the knock sensor for the motor.you may also be looking at the sending unit for the temp gauge i believe they couple be threaded into either head but i could be wrong there-thats hard to say w/o being there or seeing a pic-do you have a pic of what you saw-that could help.to answer you question regarding the oxygen sensor its in the exhaust pipe most likely before the catalytic convertor.i may be wrong there too-hopefully someone with an o2 sensor equipped truck will chime in as mine doesnt have one.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 07-11-2004, 11:39 AM   #3
clarissa
Thank you. It's a 5 liter (302) 4WD. The book I have covers the V6, mine's a V8.
Old 07-11-2004, 12:02 PM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
It'd be a 305 cid engine, really. Ford has the 302 that's referred as being a 5 litre engine most often. Chevy made a 302 i believe for the 67-69 Camaros which is extremely rare and desirable. A 305 from a C-10 most likely would not have an oxygen sensor if the engine is original to the truck along with it's ignition/fuel/emissions systems, since it should be a carbureted (4-barrel Quadrajet) low emissions engine with an Electronic Spark Control computer (knock timing retard system).
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 07-11-2004, 01:23 PM   #5
SanitysBane
rockHQ ur right on the chevy 302, came on the cameros, was a factory drag car, had a solid lifter cam in it from the factory. anways, i don't belive that anything that has a carburator would have an oxygen sensor unless someone put one in to tune the carb with.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-12-2004, 10:27 AM   #6
KShortell
KShortell's Avatar
Only California-emissions trucks had oxygen sensors for the computer-controlled carbs. If this is what you've got, it should be in the exhaust pipe between the exhaust manifold and the catalytic converter.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 07-12-2004, 12:11 PM   #7
Grim Reaper
Good luck!
Yep only cali and that's on the CCC (Computer controled Carbs). Trucks didn't get FI till 87.
Honestly if your having problems and not in Cali or a real hard core emmeions area where they pull the car apart and look for CARB numbers I would ditch the CCC and get a Electric choke Quad and a regular HEI.
Also your truck probably has ESC ignition. Again if it gives you problems...scrap and go to HEI.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
