07-12-2004, 11:34 AM | #1 |
Edelbrock 1406?
Do you guys use the ported or non-ported port for the distrubitor advance vaccum? Does it make a difference? I'm not sure which one to hook it to.
Thanks Paul
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
07-12-2004, 11:56 PM | #2 |
On both of my trucks I have it hooked to the non ported one. The one on the right of the PVC connection.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
07-13-2004, 01:19 AM | #3 |
BAD BOW-Silverado XST
Yes it does matter. I use both. It all depends on the initial timing. I use ported port for city and daily driving. At the track, I use the manifold. Using the manifold allows the timing to come up faster.
Try both. Do you plan on using an adjustable vacuum advance at the distributor? |
07-14-2004, 07:06 PM | #4 |
Its just my stock HEI distributor. I'm running out of $$ so I cant afford a new one right now. Thanks for the help guys, I hope to fire it up next weekend. I was hoping for tomorrow, but I got absoutely nothing done today except for picking up my new battery.
07-16-2004, 12:42 PM | #5 |
Parts and more parts
The non-ported fitting will give you the vacuum to get your distributor advance early, so it is a good choice, if you use your engine to hot foot it a little. The ported fitting allows the vacuum to build slowly and thus keeping your advance inset slower and allows for a milder driving style. YOUR CHOICE
07-18-2004, 02:49 AM | #6 |
Since you are starting it up, hook it up to the manifold. Once you tune and break-in (?) the engine you can change the connection.
07-18-2004, 03:44 PM | #7 |
Well had I bothered to look at the manual with it earlier I would have known. It states that the ported one is for vechiles with emissions controls, non-ported for without. So that answered my question right then. I'm gonna go with the non-ported hook up. I might try both and see which one I like better.
