07-12-2004, 12:33 PM | #1 | ||
Parting '67 1-ton duallie
Brought this back from wisconsin to my home in delano, cab is not in good shape at all (needs floors, rockers, corners and supports). 250 inline 6 starts right up, grille has 2 easily repairable dents in it, PS fender no good, DS fender needs a rear corner patch.
E-brake assy $25 shipped (hand type) - This plus everything back to the rear drums and power brake booster, master cyl and lines for $95 shipped to 9footfan Quote:
Front sheet metal (grille, headlight doors, grille support, fender to fender sheetmetal, lights, lenses) $75+ shipping Doors $50/pr you pick up Patch panels PM me we'll negotiate Non-tilt column, steering wheel with cracks $25 bellhousing/zbar/clutch/brake pedal assy $75 Vents $12 shipped ea/$18 for pair shipped Radio delete $20 shipped Scroll type door panels (metal) not rusted out $50/pr Front cowl $25 Rear diff w/tires $70 (Eaton, open carrier, 5.14 gears, descent tires/rims) Dash $30+ shipping (uncut) Gauge cluster w/choke in it, all knobs $25 shipped Gas pedal assy $25 shipped Duallie 8 lug rims $5/ea you pick up Frame + front suspension/brakes $10 you pick up Rear springs + aux springs $1 you pick up Glovebox door $15 shipped Bellhousing $30+sh Other parts FS: Cowl from '69 CST/20 $20 +Sh Rockwell T221 T-case (empty) $5+ sh 3 Chevy SBC HEI's $35 shipped $50 shipped w/cap & coil Chevy SBC flywheel (manual) $25+sh TH350 setup from my '72 (when I'm done with M/T conversion) $300+sh includes TH350, dust shield, flexplate, torque converter, linkage up to column, vacuum tube, yoke, possibly driveshaft, possibly starter SM465 shifter W/O knob $20 shipped Bellhousing w/zbar $45+SH bellhousing without $30+sh Passenger door (orange) some small rust holes in bottom good for patch panels or skin $10 you pick up Pontiac 3100 parts (block, heads, intake) make offer 4.3L TBI intake $20 shipped Qjet probably needs rebuild $35 shipped '75 C30 duallie, 6.15 14 bolt rear, 350 (ran no dist or carb), TH400, good glass except for passenger side door and driver condition doors, fixable cab, saddle tanks $75 you pick it up in Janesville WI More FS PM or post in this thread for other items. I'm keeping the manual tranny and clutch from this truck for my own. Combine multiple items and make me an offer I might just take it I will drop shipping on multiple items. I take paypal and MO's and cash. email is botboy60 (at) hotmail (dot) com Last edited by botboy; 07-14-2004 at 12:37 PM. |
07-12-2004, 01:05 PM | #2 |
72 C30 Trailer Queen
If the rear diff is a 4.10, consider it sold.
Check it out and let me know. Thanks, Chris |
07-12-2004, 01:43 PM | #3 |
how much for the hood?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
07-12-2004, 02:41 PM | #4 |
Take the hood for free, its got rust thru along the leading edge and a hole/dent big enough for me to stick my fist thru on the passenger side.
Chris H, I'll pull the cover on the rear end and I'll get back to you later tonight. Were you the guy that bought the 350/TH400 off of the '87 I parted? |
07-12-2004, 02:45 PM | #5 | |
Email sent... |
07-12-2004, 11:00 PM | #6 |
Glad to hear you are happy with it chris. According to the numbers I found on the ring gear (36:7) it has a 5.14 rear end ratio. I'll take $60 for the rear end/tires if you are still interested.
07-12-2004, 11:18 PM | #7 |
Great price, but I need to replace the 5.13 I have in my motorhome with a 4.10. 3700rpm at 60mph is just a bit too much for me!
If the tires are radial and in good condition, I would consider purchasing all 6 of the tires you have. Email or PM with size, condition and price. Thanks Chris |
07-12-2004, 11:37 PM | #8 |
get up! stand up!
how much for the e-brake assembly COMPLETE from hand lever.cables,mounting hardware all the way back to the rear drums? how much for the intermediate brake line from front to rear of truck? how much for the fuel line pump to tank? i'm interested in all. thanks in advance!!!
07-13-2004, 12:31 AM | #9 | |
Intermediate brake line is no good If fuel line from pump to tank is good (I assume you mean the one along the frame, one from tank down thru floor is gone) I can probably do $10+SH lmk |
07-13-2004, 08:10 AM | #10 |
get up! stand up!
e-brake assembly sold for 65$--please pm me with mailing address. i will pay with mo if that is ok. i'll pass on the fuel line. not important that intermediate brake line is bad i just need it for a pattern, as long as it is not spliced and has correct ends-could you provide a good description of its defect, i may still be interested if it can serve as a pattern-this line can be shipped by cutting it into thirds. also if this truck came with power brakes i would be interested in the booster and check valve,master cylinder,brake pedal pushrod, and front brake lines. thanks again. post here or pm me.
07-13-2004, 02:36 PM | #11 | |
07-13-2004, 06:34 PM | #12 |
get up! stand up!
pm'd you. all parts discussed consider sold! thanks again.
07-14-2004, 12:38 PM | #13 |
ttt
07-14-2004, 12:43 PM | #14 |
what kind of shape is the front end metal in? the grille inners trim etc etc.
07-14-2004, 02:42 PM | #15 | |
07-16-2004, 12:20 PM | #16 |
ttt
07-17-2004, 02:19 PM | #17 |
get up! stand up!
ttt for ya! thanks for the parts!!
07-19-2004, 12:30 PM | #18 |
ttt
07-20-2004, 12:16 PM | #19 |
ttt
07-22-2004, 11:11 PM | #20 |
9footfan just got your check, almost done pulling the E-brake stuff for you. Expect to have it all shipped by monday. Have a nice day!
07-22-2004, 11:42 PM | #21 |
get up! stand up!
thanks botboy--no hurry
07-23-2004, 01:40 AM | #22 |
Ill give you $60 for just the 3rd member if shippings not too painful. Its a business adress at 97266, Portland Or. I beleive it weighs about 70 lbs, Ill weigh the one I have. What is your zip code?
68 blazer buggy 68 stepside 58 gmc |
07-23-2004, 06:22 AM | #23 |
55328. Shoulda told me last week this previous weekend I was in seattle picking up a car for a friend of mine.
