numbers matching?
How do i tell if my engine is the original engine that came in my 72 swb deluxe. the glove box sticker says its had a 350 and the inner fender sticler sys it has a 350. the number in the pad on the front of the blocl is as follows: K 02 02 TJ2
how do I tell if its the right block that came with the truck? Thanks ![]() |
also, I was wondering if all truck engines are 4 bolt main . how do you tell besides removing the oil pan?
#3 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Designated A-hole!
Look for the number on the driverside back of the block and look it up here. www.mortec.com (you can look there first and get an idea of what kind of number you are looking for).
![]() Join Date: Dec 2002
somewhere on the block will be a place that will have the last part of your vin# stamped on it making it unique to that truck. For intance on my 69 camaro it is next to where the oil filter goes the same deal on the trans not exactly sure where that spot is on the trucks
#6 | |
Tim |
K 02 02 TJZ the "z" looked like a 2 sorry
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
Eng Casted/Stamped date codes
Appears to me to be too late in 1972 for this to be in your truck...UNLESS: it was ordered/Built at a very late date. Wouldnt November/72 be the new 1973 Trucks offered to the public by then...
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
thanks for the info and the link. Gonna have to have it steam cleaned to find the numbers .
Designated A-hole!
Trust me I know the feeling! The arrow shows where it should be. A little oven cleaner and the wand at the car wash should clean it up enough to read.
![]() Join Date: Feb 2002
If the casting numbers run the same as the L6s, "K 02 02" means the block was cast on November 2nd 1972. High probability it is the original engine in my uneducated opinion. No idea about "TJ2" though.
Hmmm, I donno. anybody else know?
Pennyless Fool
TJZ
yr-1973 cid-350 app-conv.cab hp-155 bbls-4 body-C10-2500 ??? ![]()
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 Last edited by BtnkBndt; 07-13-2004 at 09:04 PM. Reason: skeetun skatun skittle dee dum dee doh |
Yup, it is a '73 350. I would think the engine was swapped in at some point. It is possible that if your truck was built in very late '72 that it could be original. I am not sure how the roll out went with the new body style in '73, maybe they still built the old body style right up to the end of the year?
Tim |
#15 |
![]() Join Date: Apr 2004
Suffix code.
K= Ontario 02=feb. not nov. 02 =ground hog day tjz = what BTNK wrote,
engine suffix code,very correct! A lot of Canadian blocks were a little lower compression wise. They still run real well, I have one. Please still check the engine casting code in the location of the white arrow in the PIC. Than you will know the whole story. Sorry, the motor is not original,the engine year has to preceed the model year . Going by everything I have read about the subject. Last edited by GMC AMI; 07-14-2004 at 07:43 AM. Reason: adding info |
#16 |
For comparison May check for the sticker on the drivers door that gives the truck manufacture date. A lot of times these are pealed or painted, should also have a vin that match if the door has not been swapped.
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
#17 |
the vin is a match the door is original but it doesnt have any engine numbers. also the glove box vin is the same. Ok, thanks
#18 |
the sticker on the door says 3 / 72.
#19 |
![]() Join Date: May 2002
MOST (and I emphasize MOST) 4-bolt blocks of this era had a casting number that ended in "010" but some of these same blocks were also 2-bolt. 4-bolts are a zero advantage unless you are going to regularly turn in excess of 6000 rpm
Stepsides look like real trucks! Smitty ![]() |
#20 |
Mike's feb 72 date seems to match to the truck date of 03/72. Have to have the motor to make the truck.
LMC catalog list a few of the engine codes and the only one that I see, that may be close is VJZ - 350 for 71-72. Might double check one more time before digging in the grease at the back for the casting numbers.
#21 |
the numbers at the back are 3970010 thats at the area where the white arrow was pointing.
#22 |
Designated A-hole!
From mortecs website
3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4 Which BTW is the same casting as mine.
