07-13-2004, 09:30 AM | #1 |
205 to th350 brace?'s
i know i need one but do i need one that goes from the 205 up to the bell housing or one that goes from the 205 over to the frame? if anyone has pics that would help so i can make one. thanks
stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
07-13-2004, 12:09 PM | #2 |
I have 2 running from the bellhousing to the motor mount area and thats it. I wouldnt think it would hurt to run to the frame but you might want to leave a little for movement
2011 CCSB GMC 2500HD DMAX 73 GMC 3/4 ton 4x4 96 Chevy 1500 STD Cab Shortbed Z71 Owner of WickedWolfRC.com |
07-13-2004, 10:52 PM | #3 |
2?
do they go from them 2 bolts on the transfer case up to the bellhousing?
is one high and one low on the bellhousing? my 203 had 1 that had 2 bolts holding it to transfer case and it went up to the bellhousing. i tried to use that one but its to long and the angles arent right
07-26-2004, 11:12 PM | #4 |
My 205 has an angle brace that goes between the 2 big bolts on the pass side over to the frame. It is a big angle peice with rubber mounts between it and the frame. I will see if I can get pics, but it seems fairly simple, should be easy to fab one up.
07-26-2004, 11:17 PM | #5 | |
thats what i made
