User #12137
![]() Join Date: Apr 2004
lowering questions
i got a 67 c10 that i put a 81 chevy truck front end under(for the disc brakes) i cut the springs 1 full coil (
Gotta Startem Early
Shocks will not keep your bump stops from hitting. That is the job of the springs, the shocks then dampen the effect of the spring from, well, springing. A good set of lowered springs is the best option. You can get the sway bar brackets from Early Classic Enterprises, www.earlyclassic.com.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
User #12137
so the springs are the problem ? its alfull bouncy and it wasnt before i cut the springs ?can the bumps be cut off and replaced with shorter ones ?
Watch out for your cornhole !
![]() Join Date: Jun 2003
I take the bump stops completely off on my trucks. It keeps you from hitting them all the time.
71 DELUX
I simply cut mine down... no bumping, but still have the protection.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
The sway bar frame bracket is available at your local GM dealer part#6271375 for 17.83 or thru us at 15.00. to cure your bottoming out problem a good set of progressive rate drop coils like our EIBACH 99.00 coils will make it ride like new.
Rest in Peace Ed. Thanks for all the good times. |
Early Classic Enterprises`sway-bar mounts are made to give more ground clearence on lowered trucks.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project |
The difference between your cut spring and a spring designed to lower your truck is the load rate. You've effectivelylimited the weight that your springs can carry. If you use a spring that lowers your truck 3 inches but is still rated to carry the weight of the vehicle, you'll stay off your bumps. Same with the rear springs. If you ever plan to use your truck as a truck but want it lowered, buy springs that are still rated for 1/2 ton. It is important to relocate your rear shocks when you lower the back and to use an adjustable track bar to keep your rearend centered in the frame.
Silence is golden, duct tape is silver. - Scott |
