Old 07-27-2004, 10:03 AM   #1
mister.freeze
mister.freeze's Avatar
Instrument Cluster Help!!!
When I turn the lights on in the Fox, the temp gage jumps to hot, the fuel gage drops to E and there are no instrument lights! What happened? I'm guessing there's a short along one of the cluster lights. Anybody got a diagram of thet gage wiring and cluster lights? Thanks.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 07-27-2004, 10:27 AM   #2
donkey69
JB-80 "Twice as Good"
donkey69's Avatar
Sounds like a guy might want to make sure its got a good ground.
HEY NOW!
donkey69 is offline   Reply With Quote
Old 07-27-2004, 11:31 AM   #3
mister.freeze
I'm guessing that might be the problem, ie a short... Why is it that most folks say a bad ground as their default response to electrical problems? In my experience, overloaded circuits, chafed wires, or trauma are the cause of problems. Bad grounds are rare. I'll pull the cluster and take a gander soon, though.
Old 07-27-2004, 11:38 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
So the gauges work when the lights are off?
If so then things are being ground through the light switch.
When you turn on the lights and you now have power going through the switch,causing a short in the system.
Check for the small ground wire that attaches to the dash frame.It's there to ground out the gauge console.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-27-2004, 12:55 PM   #5
mister.freeze
Is That Via The Cluster Harness Or A Separate Wire?
Old 07-27-2004, 04:43 PM   #6
BobbyK
BobbyK's Avatar
there should be a dedicated ground wire for you gauge harness.
It has a special wire clip on it that clips onto the lip of the dash.
Old 07-27-2004, 04:54 PM   #7
BobbyK
BobbyK's Avatar
Here's what the ground wire looks like.
Old 07-27-2004, 04:53 PM   #8
mister.freeze
Thanks, all. I fixed it on my lunch break. I don't have the dedicated ground wire. One of the laminated wires on the cluster unglued itself and got laid over onto the next one last time I plugged in the cluster. I straightened it out, carefully plugged everything back, and it works like a charm.
Old 07-27-2004, 04:58 PM   #9
mister.freeze
I'll look, but have never seen it. Certainly wouldn't hurt to have if I'm supposed to. Is that a '71 thing? The Fox is a '72...
Old 07-27-2004, 05:02 PM   #10
BobbyK
BobbyK's Avatar
Possibly,not sure though.
Glad you got it fixed though.
Old 07-27-2004, 07:24 PM   #11
donkey69
donkey69's Avatar
Glad to hear you got your wires uncrossed!!
HEY NOW!
Old 07-28-2004, 03:55 AM   #12
GMCPaul
mister.freeze the ground wire is supposed to be on all dash clusters not just the 71, it is the black ground wire in the clusters wiring harness loom at it should terminate in a end exactly like the one ion the photo. Be sure that when you slide it on lip on underside of dash its on bare unpainted metal.
GMCPaul
GMCPaul is offline   Reply With Quote
