Old 07-29-2004, 04:36 PM   #1
CustomMike
radiator hoses for a LT1
I have installed a LT1 in a 1972 4x4. I would like to know how others with a LT1 have hooked up the radiator hoses since you have different size outlets on the water pump and stock radiator.
Mike
CustomMike is offline   Reply With Quote
Old 07-29-2004, 06:29 PM   #2
jorgensensc
jorgensensc's Avatar
Personally I suggest geting an aluminum radiator to help cool it down a little. You can pick up a used camaro radiator pretty cheap if you look around. if you really want to use the radiator you have you can take the smaller of the two inlets, put the hose that fits on it over the inlet, cutthe hose flush with the inlet, then slide the bigger hose over the top of that hose. You might have to put some KY Jelly on it (Don't laugh, I keep some liquid KY in the toolbox, it works great and doesn't hurt anything). be ure and clamp it down tight and it will work just fine. That's how mine is setup on my engine, with a newer radiator.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-29-2004, 06:43 PM   #3
Wootdog
Wootdog's Avatar
For the bottom hose I went to a place that makes hoses. I bought an adapter that is 1 1/4" on one end and 1 3/4" on the other. Then I connected the hoses to the water inlet and the bottom of the radiator. You will have to shorten the two hoses to put the adapter in there. By the way I also put a T for the fitting/hoses to the back of the heads. I believe it is called a steam pipe. To elaborate, the T goes between the adapter and the water inlet on the front of the engine. Hope that makes sense. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 07-29-2004, 10:05 PM   #4
CustomMike
Thanks for the responses. I have a brand new four core radiator so I don't think I will have cooling problems. Wootdog Did you put the tee for the steam vent in the lower or upper hose? Does it really matter where it dumps? On my Corvette it dumps in the radiator. I was planning to dump it in the top hose. What did you do with the upper hose to make it fit? Did you use the 1 1/4 hose and heat and stretch it over the top 1 1/2 radiator fitting? What hoses did you use to connect? did you just go to the parts store and pick and chose what looked right or did you ask for something specific? I tried some flex radiator hoses that had the two different sizes but they didn't work well at all.
Mike
Old 07-29-2004, 10:09 PM   #5
jorgensensc
Just a thought: Is it possible to weld on an exhaust type reducer? That's what I used when I did my rear gas tank conversion since the filler necks were different sizes.
Old 05-15-2020, 03:54 PM   #6
maynardogle
Re: radiator hoses for a LT1
I just finished putting a Champion 3 row radiator in my 68 C10 with LT1 engine. The radiator hoses were a bit of a challenge but I finally got it figured out. The bottom hose is a Gates 21055 which 1.75 on the radiator side and 1.5” on the thermostat housing. It fit perfect with no trimming. The top hose is Gates #20607, which is 1.5” on both ends. The top hose required substantial shortening on both ends to fit right and I installed a sleeve in the middle with a 3/8 hose barb for the steam line.. Both these hoses need to be installed with a 1.25 to 1.5 sleeve adaptor on the water pump end. The Gates number on the adaptors is #263900.
maynardogle is offline   Reply With Quote
Old 05-15-2020, 04:00 PM   #7
weq92f
weq92f's Avatar
Got pics? You sticking with the Opti-Spark or using some other type of ignition? What tranny?
I lived with an LT1 for over two decades so I'm curious.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-14-2020, 07:15 PM   #8
maynardogle
-klb
I ditched the 20 year old fuel injection and went back to f barrel carb. GM Performance manifolds has a hole for the distributor and I chose a Pertornix Flamethrower II and matching coil. No more computer, no more Optispark.
Tranny is 700R4 with TV cable control.
Pictures attached.
Old 07-14-2020, 11:31 PM   #9
weq92f
weq92f's Avatar
Pictures attached.
Look at that...nice. It's a stout motor!
-klb
Old 12-10-2024, 03:27 PM   #10
67ss&99ss
Andy
Pictures attached.
Thank you for sharing these photographs. I realize this is an older thread, but I am swapping the same engine into my 1972 K/5. What did you do for power steering hoses?
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 12-10-2024, 04:08 PM   #11
HO455
HO455's Avatar
Which LT1 version are you using? I believe the power steering pump locations differ between Corvette, F & B bodies.
RIP Bob Parks.
Old 05-15-2020, 05:28 PM   #12
jayoldschool
Moderator
Assuming we're talking 92-96 LT1, you need to remember that it is reverse cooled.
jayoldschool is offline   Reply With Quote
Old 05-17-2020, 01:05 AM   #13
68shortwide
68shortwide's Avatar
Bookmarked in case I get the itch to use one of my spares, thank you.
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 07-14-2020, 11:41 PM   #14
Warrens69GMC
Warrens69GMC's Avatar
Nice
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
