NOT REALLY BANNED!
![]() Join Date: Jul 2004
Dome light
I Was looking around my truck (Still finding new stuff), and foundout that it used to have a dome light. My question is, did they come stock on 69 pickups?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Dome lights were stock. You are talking about the one inside the cab above the rear window?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
NOT REALLY BANNED!
yup, so they came stock on all trucks or was it an option?
They are stock. Should come on when you turn the headlight switch all the way counter-clockwise if I remember right.
A popular mod is to install the door switches and wire it up so it turns on with the door opening like newer cars.
#5 | |
Alot of Trucks Came with that option After 68 there was a pad on the front of the cab between the door hinges you can drill tap and install a door light switch off any 69-87 3/8 16 is what thread it is drill a 5/16 hole tap it out fish a wire into that hole to under the dash hook it to the dome light ground wire. When tightening The switch push down on the plunger so the wire doesnt get twisted up. |
Mine has the dome light door switch option on the glovebox sticker. At first neither switch worked, so I sprayed some WD40 in 'em and worked 'em back and forth with my thumb and they started working.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
