Old 07-31-2004, 03:21 PM   #1
matt_field
matt_field's Avatar
engine guys, need more torque on 383 stroker
i have a 383 stroker in my 67 k10, and its kinda slacking on the get up and go when you get on it from a stop. its got 2.02/1.60 camel back heads fully redone in stainless valves. i put about 1,000 into the heads alone. its got a 600 cfm holley, with a edelbrock performer intake. 2.5 inch corvette ram horms. not sure on the cam but it is loppy. how can i get a little more get up and go out of it. the motor really comes alive when your going then punch it just not from a stop as much thanks
matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 07-31-2004, 03:45 PM   #2
sam's 72
What rear gear do you have? What tranny are you running? If it puts you back in the seat from a roll, sounds like you need a lower gear. If you have a auto tranny. Get a stall to match your cam, and get a lower rear gear.
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 07-31-2004, 03:48 PM   #3
Shane65
What gears in the rearend? How much vacuum at idle? This may give you some insight as to how radical the cam is. Is the accelerator pump pumping and is it enough? Is the vacuum and mechanical advance working on the distributor? 600 cfm/Performer should be responsive at the low end and 2.02 valves aren't too big.
Shane65 is offline   Reply With Quote
Old 07-31-2004, 04:20 PM   #4
matt_field
matt_field's Avatar
my rear end is 3.73 and my tranny is th350, i have a vacuum gauge in my dash, can i just read that at idle and maybe you guys can give me a better idea of what my cam is ? thanks
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-31-2004, 04:22 PM   #5
sam's 72
What size tires are you running on the back? I really don't think it will be posible to tell what lift/duration cam you have by just reading vac. I could be wrong but I can not help you on it. If you have tall back tires, that 3 73 will act like a higher gear.
Sam
72 LWB chevy truck.
Pasadena, Texas
Old 07-31-2004, 04:31 PM   #6
matt_field
matt_field's Avatar
the tires i have all around the truck are 32'' bfg all terrain, the truck does maybe run a little rich will that effect anything? i think my carb might need to be adjusted
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-31-2004, 05:22 PM   #7
sam's 72
In my opinion. I think you need more gear. 4.11, and or stall converter.
72 LWB chevy truck.
Pasadena, Texas
Old 07-31-2004, 05:28 PM   #8
Rdrdave
Broke and still trying
Rdrdave's Avatar
I would say 4.11 and hopefully you have 2.5" exhaust. The 4.11s are great for a 32" tire.
Rdrdave is offline   Reply With Quote
Old 07-31-2004, 06:39 PM   #9
charlieo
I think your cam is too big . Sounds like you get good throttle response once the motor is wound up a little but if you want great torque right off the line that cam is the wrong one. Unless you have alot of compression your cam has too much duration and the lobe centers are too narrow. Call Comp cams or Crane & tell them what u want.
charlieo is offline   Reply With Quote
Old 07-31-2004, 06:57 PM   #10
crazy longhorn
Fabricate till you "puke"
If the cam is too big, faster gears,& bigger carbs will fix it! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-31-2004, 09:05 PM   #11
browndawg71
lean out the carb if its rich. do you have a stall or not? do you have a tach if so look and get the right stall for your rpm . a stroker should have enough grunt to pull the 373s out if its not to revvy.
browndawg71 is offline   Reply With Quote
Old 07-31-2004, 10:30 PM   #12
matt_field
matt_field's Avatar
ive got the exhaust, my rear end needs to be gone threw anyways, its soooo noisy. also i was kinda thinking the cam should be replaced this winter. thanks for all your input
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-31-2004, 10:57 PM   #13
bigjimzlll
bigjimzlll's Avatar
A proper tune up can go a long way to wake up a sluggish engine....a long way
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-01-2004, 07:58 AM   #14
Blazer1970
Blazer1970's Avatar
Yup, how much have you played with the timing?
Blazer1970 is offline   Reply With Quote
Old 08-01-2004, 08:02 AM   #15
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
it's a 4x4, they arent meant to jump off the line. If you want a race truck, get a 2wd
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 08-01-2004, 01:10 PM   #16
matt_field
matt_field's Avatar
i never said it was a race truck, itd just like to get some more torque out of it. timing is screwed on this truck, listen to this you have to get it PERFECT or the thing will act like it has a dead battery, or it will ping like crazy. i had to play with it for like a day to get it so it starts and doesnt ping, its weird my distributer is a mallory unilite with a promaster coil if that makes a difference
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 08-01-2004, 03:39 PM   #17
68C15
blood type; Retumbo
68C15's Avatar
my personal experience shows that anything with a Mallory name is a waste of time. it is soooo hard to tune around an item that is not consistent. I recommend an HEI with a MSD coil. set timing to 12*, lean idle to point of wanting to die then open up 1/2 turn. if at that time you have a dead spot it is most likely due to large intake volume which needs larger acc spray. (not longer)
do you have a way to test exh backpressure? if it is over 2 pounds @ 2000 rpm that will cause a problem with larger cams which will cause it to be rich.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-01-2004, 03:54 PM   #18
dennis111
dennis111's Avatar
Does the mallory have vacuum advance or is it just centrifical advance? For best driveability you need the vacuum. I agree that an HEI is a better choice for normal driving.
Other than that it sounds like you might have too much cam for your liking.
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 08-01-2004, 05:27 PM   #19
matt_field
matt_field's Avatar
my mallory is just centrifical advance, i should try out a hei with a new coil and see how that goes. i have never liked that unilite thanks
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 08-01-2004, 07:07 PM   #20
Shane65
Bingo! You need vacuum advance for street driven vehicles. Non vacuum distributors work well for race vehicles and that's it.
Old 08-01-2004, 09:50 PM   #21
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
Have you actually tuned your Holley? Personally, I don't think it is cam, timing, CFM, exhaust or anything else that has been mentioned. If you took the holley out of the box and bolted it onto your engine, it is most likely not set up correctly for your engine.
If you have a mechanical secondary carb and an automatic, sell the carb and buy one with vacume secondaries. Then tune.
If you have a vacume secondary carb, it sounds like you need a stronger spring in the vacume chamber that will slow down the openning of the secondaries.
More CFM will make your problem worse, not better. You have the right cfm for your motor. Now just tune the carb.
If you want more info on tuning a Holley, please e-mail me offlist.
Ogier
Ogier is offline   Reply With Quote
Old 08-01-2004, 10:35 PM   #22
bigjimzlll
bigjimzlll's Avatar
Ogier
while I agree that a properly tuned carb is a must...the statement that the 600cfm is the "right" cfm for his engine is a little bold. He has a "lumpy cam" and it is a 383. The carb will work...but it is not optimal for performace. A 4160 would be my cam of choice for his application
Anderson,CA
Old 08-02-2004, 12:53 AM   #23
Blue4x4
Blue4x4's Avatar
I'm using the hei dist on my 383 and no complaints here. 3.73 gears and 4 wheel drive. let us know.
Blue4x4 is offline   Reply With Quote
Old 08-02-2004, 07:55 AM   #24
bigjimzlll
bigjimzlll's Avatar
Ogier,
I wasn't trying to be a smart azz....I know all of the CFM formulas too. I always fall back on what GM did, and ofcourse personal experience. For a daily driver with a max rpm of 4500rpm, im sure the 600 would work OK, im also sure a properely tuned Qjet would be better. The Qjet is a little more than 600cfm. GM used 750s and 780 holleys with good sucess<sp>.
On the 455 im sure there was no hesitation or bogginess with a 600cfm carb, but there was a few HP left on the table.(IMO) Maybe im just out of touch(with pure street) tunning.
Anderson,CA
Old 03-07-2018, 04:18 PM   #25
ThunderTruck
Re: engine guys, need more torque on 383 stroker
I have a similar problem with my '72 2WD C-10.
I built a 383 years ago (I was 15 and thought I was tough but really just dumb...), and it has always just been way too revvy and high-strung for a street truck.
Here are the basics of the build:
800cfm Edelbrock Thunder series Carb
Weiand Team G Single Plane Intake manifold
World Industries heads with 220cc intake runners, 64 cc combustion chamber - I think it is running 10.5 to 11:1 compression...
Crane Cams Flat tappet hydraulic cam - Advertised Duration 294/300, Lift .502/.516
1.6:1 Roller Rockers
MSD Ignition
Headers with 3" true dual exhaust and LOUD mangaflow? mufflers
I'm running the stock SM465 Muncie with 3.73 posi rear end, and it is just really boggy and hesitant below 3,000 RPM. I have it rev limited at 6,000 but seems like it would rev to 8k if I let it.
Here are my initial thoughts....
1. Run some break-in rockers with a 1.35:1 ratio? Maybe more expensive and difficult than just swapping the cam and keeping the 1.6 rockers, but just throwing it out there.
2. Install a dual plane manifold? Edel brock makes some affordable options. Maybe keep the single plane and run a restrictor plate?
3. More restrictive/quieter mufflers
I'm trying to avoid swapping the heads and cam. I live at 5,500' altitude so maybe I can get away with the high compression on pump gas. I've re-jetted the carb per Edelbrocks recommendations and it helped a little bit. I can't run the initial timing any less than ~18 degrees without backfiring/flames coming out carb and/or starting issues.
I'm interested to hear any and all thoughts on the easiest and most economic ways to calm this beast down!
ThunderTruck is offline   Reply With Quote
