08-03-2004, 08:24 PM | #1 |
10 to 12 bolt...what u joint do i need?
i'm swaping my 10 bolt out with a 12 bolt this weekend. what u joint do i need that will work with the driveshaft i have now and the 12 bolt pinion?
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
08-03-2004, 08:49 PM | #2 |
BAD BOW-Silverado XST
Spicer 372. This ujoint has held up better than two other replacements. I like it.
08-03-2004, 09:19 PM | #3 |
I went to carquest and picked one up, no trouble from it yet, but it hasn't been in there very long, maybe 7 months or so. Been through hell though, VERY dusty gravel roads, off-roading, and a few thousand miles. But the Dana/spicer joints are the best and the strongest.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
08-03-2004, 10:34 PM | #4 |
thanks G. do most parts chains carry the spicer joints?
08-03-2004, 11:06 PM | #5 |
Garage Queen Material
whats in the 12bolt again? i dont feel like searching. what gears did you decide on?
08-03-2004, 11:16 PM | #6 |
Slots go on anything!
When I used the 10 bolt driveshaft from the 82 Blazer in my 77 equipped with a 12 bolt, I had to use a combination joint from NAPA. Amazingly, the 12 bolt had smaller caps and cross than the 10 bolt driveshaft u-joint.
1974 Jimmy- 5.3/4L80e/NP241 |
08-03-2004, 11:54 PM | #7 | |
eric, i went with 3.73 richmonds and a powertrax lock right locker. dropped the rearend off at the shop tonight to have the gears set up, should be done on thurs or fri, gonna put the rear end in on sunday
08-04-2004, 12:00 AM | #8 |
damn you. always 1 step ahead of me
why did you choose the powertrax over anything else? i'm thinking of going with an eaton and 3.73's |
08-04-2004, 12:12 AM | #9 | |
08-04-2004, 12:14 AM | #10 |
and as far as being 1 step ahead of you, i had this 12 bolt for 1 1/2 years just be sitting in the garage wait for me to get the money to build it
08-04-2004, 02:58 AM | #11 |
NAPA has the joints in stock. Not sure about other stores. They can probably order them though.
08-04-2004, 03:08 AM | #12 |
My NAPA guy didn't have one in stock, so he made one from 2 others, & only charged me for one.
08-04-2004, 04:09 AM | #13 |
Presicion part # 447
08-04-2004, 01:58 PM | #14 |
You got the 10bolt...swap the yokes. It takes a different seal but they are readily available. bring both the 10 and 12's seal. They need to get the numbers off each and then they can cross refference it. The 10 uses a stronger u-joint. Go to NAPA. Autozone people are too stupid to do this.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-04-2004, 04:07 PM | #15 | |
You get what you pay for
Mike 1985 Chevy C-10 |
08-04-2004, 05:44 PM | #16 | |
