Old 08-05-2004, 10:39 AM   #1
SLS
Finish the'71..or bust!
SLS's Avatar
What was the original color of the tailight housings??
I am working on my bed (71' SWB) and decided to detail the tailight housings (I guess that's what they are called?) because the were covered with funk and old primer when I got the bed.
Anyway, I have blasted and primed them...but what color are they supposed to be. White perhaps???
Thanks for any info.
SLS has attached this image:
SLS is offline   Reply With Quote
Old 08-05-2004, 10:53 AM   #2
highboy_04
highboy_04's Avatar
i believe they were just bare and had no coating. goodluck, steve
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 08-05-2004, 11:06 AM   #3
Lippyp
English Chevy Owner
Lippyp's Avatar
You may have grounding problems with them painted as don't the bulbs ground via the housing?
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 08-05-2004, 12:00 PM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I'm planning on painting mine with Rustoleum Metallic silver after I get them sandblasted. That should give more reflection for a brighter light. Second choice would be white.
To ensure a good ground, use a tooth type washer on each bolt.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-05-2004, 01:32 PM   #5
SLS
SLS's Avatar
Thanks for the replies so far, guys.
I believe you may be on to something about the grounding situation, Lippyp.
Maybe I should make sure that I leave bare metal showing where they bolt/screw into the bed. I hate to just blast them back to bare metal and intall them as such......as I already have enough rust issues as it is. LOL! ;D
Old 08-05-2004, 02:54 PM   #6
Davy
Davy's Avatar
Mine look like they are galvanized steel ???
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 08-05-2004, 03:13 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
They are in fact galvanized steel, and will not rust. I have painted mine white and it helps a little on brightness...but not a whole lot. And sanding it to bare meatle where the two 5/16ths headed bolts go through is a must, and don't forget to tape off the actual bulb socket so you don't ruin the contacts.
Old 08-05-2004, 03:39 PM   #8
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I replaced both of my taillight lenses a while back and I saw that the housing was painted white, and the inside of the backup lamp housing was white, too.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-05-2004, 10:07 PM   #9
SLS
SLS's Avatar
Galvanized...didn't think of that. Maybe because they still had some surface rust on them. They are stamped "Guide-Made In Canada" so maybe are different?
Good advice on the sanding of the mounting surface and taping of the sockets...which I did after removing the wiring and before lightly blasting them. I also used a wire brush thing (shaped like a bottle brush) to polish up the brass bulb sockets....the shine like new now. Wish I could say the same for the rest of the truck..LOL.
Longhorn Man:
Is that Longhorn Website something you put together? It is AWESOME! I really enjoyed reading it and look at all the great pictures. That two-tone gold and white is starting to grow on me....
Old 08-05-2004, 10:31 PM   #10
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i painted mine 'chrome' just cleaned up all grounding points and they work fine. no problems
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 08-06-2004, 12:04 AM   #11
Longhorn Man
yeah, did that site. I realy oughta update it one of these years.
Thanks for the comments SLS.
Old 08-06-2004, 07:40 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
I would paint them white after soldering a ground wire to back of housing. that way there is no chance of rust. use some dielectric grease on grounding points.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
