08-07-2004, 08:55 PM | #1 |
How do you Remove an AT cross member?!
I'm parting out a donor truck to convert my 6cyl 3 on the tree to an V-8 TH350 and I need the cross memer from the donor truck. The rivets / bolts are out, but it seems to be wedged too tight between the frame rails. I was figuring I would rotate it and get it to fall out, but that doesn't seem work.
Any thoughts would be appreciated. Thanks Brian |
08-07-2004, 09:03 PM | #2 |
Watch out for your cornhole !
Hammer and a block of wood, they usually wedge in there. The crossmememer does need to rotate to fall out from between the frame rails
08-07-2004, 09:26 PM | #3 |
Maybe rotate wasn't the right word....possibly twist is more appropriate. None the less drive one side forward and the other back and it should come out of there aye?
08-07-2004, 09:43 PM | #4 |
Thats how I installed mine, Im sure reverse is the same. Hit one side then the other. Might be easier if its a junk truck, can cut the brake cables.
1971 LWB Chevy C-10 350/350 3:42 eaton |
