Old 08-07-2004, 11:46 PM   #1
ALBATROSS
Big block ?
Hi All, I know this is been discussed about a million times but I dont see a search on this site. What is involved to put a big block in a 71 4x4. I know obviously motor mounts. A friend of mine swears that should be it. But I remember reading on here that it's not. I thinking of building either a 468 or a 496 not sure yet.But i want it injected, I've got a 383 right know but I NEED MORE POWER! Any help would be greatly appreaciated.
ALBATROSS is offline   Reply With Quote
Old 08-09-2004, 10:19 AM   #2
Yukon Jack
Yukon Jack's Avatar
I read up on this subject prior to putting a 454 in my 69 K20. Generally I read you could use your original crossmember/towers and motor mounts and you would have to bash in the firewall a bit. Also read some said a minor body lift would give you adequate clearance. Others said all you have to do is move the engine forward a bit. Using a newer engine crossmember is supposed to make life easier if you are going with headers.
I went with doing a body lift and at least for me a 2" body lift did not give adequate clearance at the firewall using the stock crossmember/towers. I had to go with a bigger body lift and still had to modify the firewall considerably.
I will move my engine forward in the future and I think that is the best option. I think moving the engine forward 1 1/2 to 2" forward should be sufficient.
I have seen pics of trucks where the owner states it is in the small block position with minor firewall massaging, but for the life of me I can't see how that is possible after seeing the amount of firewall interference I had.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-09-2004, 04:23 PM   #3
ALBATROSS
Thanks Yukon, I also have a 2" body lift, but I will probably go with moving everything 2" forward. I also have a 14bolt and eight lug 44 so it might be best to do them at the same time since I will have to have a driveshaft built anyway.Damn the front shaft will probably need worked too. I 've got a 6" lift and the angle is already questionable. I can see the $$ adding up real quickly on this one.
Old 08-10-2004, 12:34 PM   #4
ryanroo
ryanroo's Avatar
i had a 454 in my 72 to check for clearance probs and i really didn'thave any, the Pass side head was clase to the firewal, but i tapped it in a little with a hammer to fix that. the only problem i could see was my headers interfering with the clutch linkage. i have no body lift and rotten body bushings.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 08-11-2004, 09:46 AM   #5
smokekiki
Mike
smokekiki's Avatar
My 71 4x4 suburban has a 402 in it.The valve covers where very close,but cleared.I hammered and smoothed the firewall just a little for clearence.You can't even see it.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-11-2004, 09:57 AM   #6
Destructo
So what was the difference between a factory big block truck? Maybe if yall knew that then you could determine the best way to make it fit. Was the factory big block further forward?
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-11-2004, 10:16 AM   #7
smokekiki
Mike
smokekiki's Avatar
They never made a pre73 big block 4x4.You have to decide to massage the fire wall,or move the engine ,trans transfer forward,or move the engine forward and install an od trans.
