Old 08-09-2004, 01:39 PM   #1
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Hood hinges
Well its time to clean up my hood hinges. Can I just blast em with aluminum oxide or do I have to use plastic media? Worried the aluminum oxide might stress em or somthing. Paint em up with Krylon semi-flat? No bucks for powder-coating or chrome.
Thanks for any input.
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 08-09-2004, 04:20 PM   #2
Blue68
Blue68's Avatar
Don't know why you couldn't use sand or aluminum oxide. They aren't going to warp on you from heat and they are just steel. Granted, you'll need to make sure the pivot pins are clean. Semi-flat sounds right, but I'd prime with a self etching primer myself first, just to get a little smoother surface.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 08-10-2004, 10:42 PM   #3
Don Smith
I don't know this from personal experience, but I have read that blasting springs makes them lose tension.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 08-10-2004, 10:47 PM   #4
chickenwing
I know that blasting metal hardens it and makes it brittle. Dunno if it could hurt the hinges/springs though. Probably not the hinges?
Old 08-11-2004, 07:22 AM   #5
67chevemall
67chevemall's Avatar
Air and WD 40 should clean em! Little castrol super clean!
Paint em up, and don;t forget to oil the piss out of em!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-11-2004, 07:37 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If it will fit into my blasting cabinet, it gets blasted. No problems ever with doing hinges.
You will need to clean them with a solvent too though, to remove years of buildup of spray lubes put on the hinges by previous owners. Otherwise, your paint will fish eye.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-11-2004, 07:57 AM   #7
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I've blasted many with just sand. Never had a problem and wouldn't hesitate to do more.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-11-2004, 08:59 AM   #8
theo70
COMING SOON...
theo70's Avatar
I picked up a hinge at a local yard and blasted it with sand. Two thin coats of engine black, and you would swear it was powdercaoted. I've found that if you lay it on too thick it will have a satin-like finish, though.
theo70 is offline   Reply With Quote
