The oddest Todd around
Gear Drive
Has anybody here ever used the gear driven timing other than a timing chain? What were your results / experiences with them?
Todd |
Chopper/Painter
Yes, Many times.
Keep your HP under 450 and you will be fine. I have only had failures in the post 450Hp range. ![]() Ogier |
Gear drives
I had a Pete Jackson in a 71 El Camino & never had a problem with it.
gear drives are noisy, but don't stretch
#5 | |
Keep On Truckin'
I bought a nice used Pete Jackson "quiet" set for a 350 I am building only to find out I can't use it since the engine is fuel injected and has a knock sensor. Apparently, the sound of the gears affects the computer when the knock sensor picks up the noise. If you are interested, I will sell you the set for $75 shipped to your door. They are about $150 new.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
I"ve been running an Edelbrock gear drive(slightly noisy but not as loud as the Pete Jackson ones) for the last 6 years. The engine is fuel injected and has a knock sensor. I can read what the knock sensor is doing with my laptop and there is no issue with the gear drive sending readings to the emc.
#7 | |
Keep On Truckin'
Interesting.... I wonder if the Pete Jackson set up is just too noisey as opposed to the Edelbrock setup?
