Old 08-10-2004, 10:18 AM   #1
TrainD5115
North Coast, baby!
TrainD5115's Avatar
creased hood
On an otherwise rust free 79 Scottsdale, my hood has decided to fold (bend) in the middle especially near the outer edges where a small amount of rust was found. Are these hoods normally this weak or is it a hinge problem? Any feedback is appreciated.
79 Scottsdale C20 aka Big Bird
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 08-10-2004, 10:32 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
The hoods are weak, but the problem is the hinges. Unfortunately the design of them allows them to become harder to close and create extra pressure on the hood at a weak point....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-10-2004, 10:34 AM   #3
78ChevySilverado
I love my Chevys
78ChevySilverado's Avatar
Unhappy
Yes this is a common problem. The hood was designed to fold up in the middle on impact in a crash. The problem is, whenever your hood hinges start to crap out on you and you continually try to close the hood against the unwilling springs it causes the hood to crease in the middle. So I would suggest either getting some new hood hinges. But before you go and buy any you might want to check and see if they are both straight because if they are off they will sway or bend and this can also cause that problem.
78ChevySilverado is offline   Reply With Quote
Old 08-10-2004, 10:38 AM   #4
78chevstepside
78chevstepside's Avatar
Its both. Around 75 they changed the disign to bend in a crash. theres a weak spot in the hood by disign. When the hinges dont get properly oiled this causes the hood to crease in the middle. I In am on my 3rd hood on my 78. In 1980 right when I bought my 78 a buddy asked a gas attendant to check the oil. big mistake he couldnt get the hood to close so he pull down instead of pushing in and bent the hood. I replaced that hood with a early model that was solid in the middle. when I had the truck repainted in 1992 that hood was replace because it rusted from the inside out. They sell stifners for these trucks. Best to keep the hinges oiled.
78chevstepside is offline   Reply With Quote
Old 08-10-2004, 01:07 PM   #5
76bonanza
76bonanza's Avatar
Yes oiled hinges are the best cure.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 08-10-2004, 02:34 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
oiled / new hingers are good if your hood isn't already toast. I just replaced my hinges/springs, but my hood is already tacoed so it doesn't close flush in the back. Pretty much the only cure for that is a new hood unless you think you can bend it like beckham.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 08-13-2004, 10:19 AM   #7
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Thanks for all the info guys.
Brad
79 Scottsdale C20
350/350
3.73's
Old 08-13-2004, 10:46 AM   #8
75-K5
Bucket of Bolts
And whatever you do, don't get the so-called "hood braces" from LMC, they are the biggest waste of money on earth! How can a piece of steel you can bend by hand be strong enough to keep a whole hood from creasing?
This is the project that never ends, yes it goes on and on my friend....
75-K5 is offline   Reply With Quote
