08-10-2004, 12:53 PM | #1 |
Polyurethane Panhard Bushings?
Does anyone know where I can get polyurethane panhard bushings for my stock panhard bar?
Just sitting here contemplating contemplation. |
08-10-2004, 01:06 PM | #2 |
08-10-2004, 01:11 PM | #3 |
chris
I think I got mine from GMCPauls. Yep found the receipt the PN was J-RTAB302 for the "Track Arm Bushing" This was actually in 2002 so you probably could check the number. They were 17.00 at the time Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-10-2004, 01:12 PM | #4 |
Thanks guys.
08-10-2004, 04:12 PM | #5 |
my local autozone,pepboys and advancedauto all carry them over the counter
08-10-2004, 11:15 PM | #6 | |
08-11-2004, 07:23 AM | #7 |
The Energy Suspension part number is 3.7104 (60-72 Rear Tracking Arm Bushing Set). You re-use the outer sleeve of your existing bushings. I got my set at the local parts store for under $10. My original bushings were shot so you could shake the bed side to side and get a lot of movement (and a clanking noise). The new poly bushings made things tight again.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
08-11-2004, 02:08 PM | #8 | |
08-11-2004, 02:23 PM | #9 |
That is the part number for the 1/2 ton panhard bar (tracking arm) bushings. The part number for 3/4 ton panhard bar is 3.7116 . The part number for the rear trailing arm bushings is 3.3123 . Here is the link for Chevy 2wd Trucks: http://www.energysuspension.com/pages/c2wd1.html
