Old 08-10-2004, 03:24 PM   #1
53burb
53burb's Avatar
Power Brakes
I have a '69 2wd 3/4ton Burb with Drum brakes in front and no power. I read about using a 3/4 booster versus a 1/2ton booster. What do I need to complete this conversion?? I am going to be changing to disc brakes in the future. Are the boosters the same for drum or disc?? The master cylinders are different between the two, but I will worry about that later...
Chris
53burb is offline   Reply With Quote
Old 08-10-2004, 08:10 PM   #2
JimKshortstep4x4
Smile
3/4 ton boosters can be readily installed if you have the brackets and brake rod. You may find that your master cylinder will not bolt up to the booster, but I believe that it will. The booster will work fine with disc brakes when it is time to upgrade.
Adding power brakes to drums will help you stop. It will be a good thing to do.
Jim
Old 08-10-2004, 08:49 PM   #3
Scottri
Scottri's Avatar
You will need to find the correct master cylinder. I have a 69 GMC 3/4 with all four drums and it had no power brakes. I got the booster, bracket and replaced the master cylinder.
Scott
1969 GMC 3/4 Ton Long Bed Fleetside
350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb
Beaverton / Portland Oregon
Scottri is offline   Reply With Quote
Old 08-11-2004, 12:43 PM   #4
53burb
53burb's Avatar
Do you happen to know the parts needed or part #s?? Is it a simple bolt-in??
Chris
Old 08-11-2004, 01:42 PM   #5
krue
Designated A-hole!
krue's Avatar
It's pretty easy. Just unbolt the m/c from the firewall, unhook rod from brake pedal, install booster, stretch m/c lines long enough to bolt it to booster, and connect rod from brake pedal to booster.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-11-2004, 03:26 PM   #6
53burb
53burb's Avatar
Can I still use the same rod?? Does the hole that the rod goes thru the same size as the booster would use, or does it need to be enlarged??
Old 08-11-2004, 03:32 PM   #7
krue
Designated A-hole!
krue's Avatar
You need the rods that come with the booster. Actually you need the rod between the booster and m/c and the rod between the pedal and the booster.
www.daveramsey.com
Old 08-11-2004, 03:46 PM   #8
53burb
53burb's Avatar
Can I get those from AutoZone or Checkers?? Or do I need to get those from another supplier??
Old 08-11-2004, 05:44 PM   #9
krue
Designated A-hole!
krue's Avatar
Your best bet is the parts board here.
www.daveramsey.com
Old 08-12-2004, 05:42 PM   #10
53burb
53burb's Avatar
Thanks for the help....
