I GOT A 90 SUBURBAN AND I GOT NO BLINKERS AND NO BRAKE LIGHTS I GOT RUNNIN LIGHTS AND EVERYTHING HEAD LIGHTS FLASHERS AND EVERYTHING WORKS IVE CHECKED ALL THE FUSES ALL WERE GOOD NO LOSE WIRES NO WIRING BURNT OR TOUCHING I COULD SEE PLEASE HELP THIS IS MY DALIY DRIVER!!!!!HELP
Brakelight switch under the dash gone bad?
#3 | |
Thanks For Your Help
Professional Grade
Check to see if your brake light's ground is good, if you've got a bad ground, your lights will be so dim that you'll barely see them during the day...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Do the gages bounce when the blinkers are on?
What happens when the running lights are on and you hit the brakes or the signals. Thats a sign as well as the others you posted that the ground strap off the passengerside head to fire wall is missing.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
ok guy's ill check that cause it still does have brake lights the altenator gauge was bouncing alittle so ill check it and let yall know if that worked or not thanks for all the help i app.it thanks again!!!!!
