Old 08-15-2004, 11:00 PM   #1
TheBobbyTrain
lug nuts broke off
I was on my way home, towing my boat from the lake when I noticed that there was a strange noise and grinding feeling coming from the rear driver side wheel. Luckily I was about 200 feet from my driveway when I noticed this so I went ahead and drove home, parked the boat, then looked to see what happened. I found that 2 lug nuts broke off along with the studs. Anyone know what caused this and how much is it going to cost to get fixed?
TheBobbyTrain is offline   Reply With Quote
Old 08-16-2004, 02:53 AM   #2
alf4444
alf4444's Avatar
If its on the rear wheel and you launch your boat with that truck alot they probably just rusted cracked and broke. Its an easy fix and should only cost a little bit. Just make sure you press the old pieces out carefully if not you could damage the hub and that increases the repair cost alot!
Good luck
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
