Old 08-29-2004, 03:02 PM   #1
Piper71c10
Unending Project
Piper71c10's Avatar
Gas Gauge Help?
My gauge reads over full all the time. I've checked the sending unit, and the wire to the unit, but I don't know what to do next. Any help?
Piper
Piper71c10 is offline   Reply With Quote
Old 08-30-2004, 11:04 AM   #2
60-66 Nut
Professional Beer Tester
Piper,try unhooking the wire at the sender,turn the key on,and watch the gauge.If the gauge doesn't move,then touch the wire momentarily to a good ground.This won't be the same resistance as the sender,but it should tell you if the gauge is working at all or not.If the gauge doesn't move either way,you probably have either a bad gauge or the wire could be broken or shorted to the gauge.If it does move,then more than likely it's the sender.Hope that helps.Lynn
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 09-01-2004, 08:05 PM   #3
Piper71c10
Unending Project
Piper71c10's Avatar
Thanks for that tip! Should've thought of it myself, but that worked, and I discovered that my sending unit was bad. Threw another one at it, and BAM! The tank reads correctly. Whoduve thunk?
Piper
Old 09-02-2004, 09:12 AM   #4
60-66 Nut
Anytime.Glad that worked for 'ya.
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 02-27-2005, 03:47 PM   #5
fellerb
Who did you buy the sender from?
Fireman Bill
fellerb is offline   Reply With Quote
Old 02-27-2005, 09:42 PM   #6
Piper71c10
Unending Project
Piper71c10's Avatar
I didn't buy one, I had one lying around from another truck....
Piper
