Old 08-31-2004, 07:16 PM   #1
winnipegk5
winnipegk5's Avatar
Cruise control problems
I have a 79 Suburban that I am trying to get the cruise working on. It is a 2wd 350 AT. So far I have:
1) Power from the switch to the controller it clicks on and off when I push the end of the turn signal
2)The speedo works fine and is accurate
3) If I provide vacum to the throttle actuator it pulls the throttle linkage.
Nothing happens when I put the cruise on at highway speed. I can here it clicking under the hold but it will not maintain the speed.
Any tips would be much appreciated.
Thanks in Advance
Mike
winnipegk5 is offline   Reply With Quote
Old 09-01-2004, 03:41 AM   #2
the baron
the baron's Avatar
have you already checked the adjustment of the switch situated on the brake pedal ?
If that one is bad adjusted , your C.C. system never will engage
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 09-01-2004, 06:50 AM   #3
winnipegk5
winnipegk5's Avatar
No, but I will check it this morning. Does anbody have a wiring/vacum diagram?? My manual has 81 and up only.
Mike
Old 09-01-2004, 09:42 AM   #4
the baron
the baron's Avatar
I have a 1980 Service Manual , I don't know if if it will help you or not...
Old 09-01-2004, 09:58 AM   #5
Greenlee
Greenlee's Avatar
I'm interested in this question too. The cruise on my 76' works sometimes, and other times it doesn't. I hope it isn't the turn signal button as I notice in the LMC catolog that the turn signal assembly with cruise cost something like $129.00.
Greenlee is offline   Reply With Quote
