08-31-2004, 07:52 PM | #1 |
HELP converting brakes
Can someone explain to me why i would have to change the master cylinder and proportioning valve on my 69 to convert it to 73+ disc brakes. I bought drop spindles that take 73+ discs and i was just going to connect the lines that went to my drums to the new discs calipers. Will this not work? If anyone can explain the proper process on trading my brakes it will be greatly appreciated
08-31-2004, 08:04 PM | #2 |
Designated A-hole!
Basically the disc brakes on the front and the drum barkes on the rear use different pressures to operate. That's why the proportioning valve from the drum/drum won't work. As far as M/c goes, the disc brakes use more fluid (as the pads wear the caliper has larger volume of fluid in it) so the reservoir is larger. I could be wrong, if so, someone wil jump on here and correct me.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-31-2004, 08:21 PM | #3 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
08-31-2004, 09:52 PM | #4 |
So if i were to buy everything for the conversion This is what i will need.
Rotors, loaded calipers, inner and outer wheel bearings, proporioning valve, master cylinder. Is there anything else i need (is there a hub?) |
08-31-2004, 10:13 PM | #5 |
The hub will come with the rotors, or a least that has been my experience with rotors for our trucks. You will also need new flexible hoses to go from hard line to calipers.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
