Old 09-04-2004, 09:01 PM   #1
Wootdog
Wootdog's Avatar
Thumbs down Tach Dash
I was looking over some posts that I frequented awhile ago about a tach dash. Well I can not find who I bought it from. It doesn't work. I would like to know what the resistance is supposed to be with a multimeter to be good. I am showing an open. It doesn't matter how I connect it, it don't work. Showed 800 rpms the first time I fired up the truck and nothing since. And the temp gauge don't work either. The amp gauge and the fuel gauge do though. Just venting Kerry.
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 09-05-2004, 06:09 AM   #2
JimKshortstep4x4
Smile
I took some readings off of a working tach. Coil to ground is 3.37 m ohms.
12v post to ground starts out at a very high reading and goes to infinity, (open). It must have a capacitor in the circuit because the way to get a reading is to read coil side first.
I suspect that checking with an ohm meter is not the way to test a tach.
Jim
Old 09-05-2004, 09:08 AM   #3
Wootdog
Wootdog's Avatar
Thanks.
the problem I have is that one side has to go to 12vdc and the other side to the computer for the LT1. I see the voltage vary coming out of the computer for the tach line. The tach looks like it went to 800rpms and then hasn't moved since. I have wired the whole truck without any problems until now. I swapped the two wires and no change also. Makes me think I am missing something. Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 09-11-2004, 11:13 AM   #4
Wootdog
Wootdog's Avatar
Ttt
Anyone? Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 09-11-2004, 01:28 PM   #5
olblue60@aol.com
member
I have a collection of antique tachs and guages. I have never tried to hook any of them up, but I have been warned to use a Tach adapter when hooking to electronic ignition. I dont know anything about the hookup, but there is a vendor in the Hemmings Motor News, "Williamsons" ,who is a father, son-inlaw pair with a great reputation of tack and Guage restoration,who are always more than happy to give out free advice. Great vendor,you might give them a call.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 09-11-2004, 01:53 PM   #6
Kleantouch
Kleantouch's Avatar
I bought a tach dash/vacuum etc. to hook up to my 71 Blazer- I also put a 454, HEI distributor and a painless wiring harness in- When I first hooked it all up, the tach would bump with the starter, but when the engine fired- nothing- one wire +12vdc, one wire straight from the tach terminal on the hei distributor, and the tach itself grounds thru the dashboard ground. I *****ed at the guy who sold it to me, blah blah blah. Turns out my bayonet connector at the dist was not engaged on the prong- put it on correctly, tach works fine. If you have a resto dash, the tach should have two connectors- the one on the left side as you are looking at the back of the tach to the disty (or pulse source) and the right- as you are looking at the back- 12vdc, and it should ground thru the dash case- your wiring harness should have a ground wire at the plug which grounds everything. make sure you have the dash grounded- 99% of all electrical problems are bad grounds. Good luck!
Kleantouch is offline   Reply With Quote
