Old 09-05-2004, 06:51 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
ignition switch removal help (cant search)
i know this has been brought up before but how do u get the ignition switch out of a 71?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 09-05-2004, 06:53 PM   #2
thisolechevy
there is a little hole on the front of the switch, put the key in and turn it to the right to the acc. position. next push something small and hard into the hole you will fell it depress then turn the switch counterclock-wise until it stops, you may have to do this several times until it is freely moving. Then using the key remove the switch through the front of bezel.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 09-05-2004, 06:55 PM   #3
Blue85
Oilfield Trash
Blue85's Avatar
put in the pin then turn or the other way around? After that the bezel should just screw out?
87 Chev 3+3 4x4
Old 09-05-2004, 07:47 PM   #4
vtblazer
vtblazer's Avatar
Just did this today...
The first post is correct.
Insert key, turn to accessory position
Insert paper clip or similar into hole, you'll feel it depress. (as mentioned)
Turn key (lock assembly) counter clockwise and it should come out.
Then, yes the bezel just unscrews.
Keep trying, it almost never seems to work the first time...
vtblazer is offline   Reply With Quote
Old 09-05-2004, 08:18 PM   #5
thisolechevy
Nope it will almost NEVER work the first time!! I did it atleast 15+ times before it worked I was ready to take a power hammer to it, just keep at it though.
Old 09-05-2004, 10:27 PM   #6
donkey69
JB-80 "Twice as Good"
donkey69's Avatar
The big P is the key......patience!!
HEY NOW!
donkey69 is offline   Reply With Quote
Old 09-06-2004, 06:14 AM   #7
Blue Beard
Blue Beard's Avatar
I use liquid graphite before trying.
It flows throught the lock and lubes everything, usually making it easier to get out.
Don't get the graphite on your cloths, it will stain them.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 09-06-2004, 09:49 AM   #8
70c10
67-72 Addict!
70c10's Avatar
They actually make a special tool to safely remove the bezel portion.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-06-2004, 12:19 PM   #9
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
A little WD-40 also helps
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
