Why Buy New?
i'll need to replace both rockers and a portion of the floor pan,cab mounts and such. any advice? any repair pics? thanks in advance!!!
'71 GMC 1/2 Ton LWB '71 Chevy 3/4 ton Longhorn |
you will be best off pulling the front fenders...
lay the new one's up there...make out with magic marker.. cut 1/4 inch smaller....clean...welder up....tack weld.... my tig welder has a pulse,, for doing such a thing....don't over heat.... seam seal....prime..paint... ![]() |
What are you looking at?
welcome to the board fellow Okie
1971 GMC LWB 2005 Honda Element 2007 Honda Fit ![]() |
I built a cab stand with some scaffolding material. I weled it so that the cab supports sit on it. It lifts my cab about 2 feet off of the ground and is a lifesaver for working under the cab. as far as the welding. remove the rockers first. the inner rockers will probably have to be done also.cut the floor out and mark the patch with about an extra half inch all around. fine shpe the piece so you get a good weld and weld the floor. next do the inner rockers and then the outer rockers. I recently redid the floors in my cab.
