Old 09-14-2004, 08:11 AM   #1
88Jimmy4x4
88Jimmy4x4's Avatar
replacing wiper/cruise/turn signal selector...how hard?
My 1990 Burbs wiper/cruise/turn signal selector lever is pretty worn and none of the text is legible anymore so I want to replace it with a new one.
I saw one at my local O'Riellys auto parts store for $30....are these any good?
Do I have to remove the steering wheel to replace this?
It looks like just one wire to plug in, and the end of the shaft is round, how is this held in?
As you can see I need any and all the help I can get with this
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-14-2004, 07:09 PM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
wow so those things really are as huge as they look in LMC
I don't think its that hard to put in, not sure HOW it goes in, but my dad had my teeny turn signal lever out to install a horn button on it (don't ask)
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-14-2004, 07:21 PM   #3
RockHQ
ROCKET POWER!
RockHQ's Avatar
Just yank the old one loose from the steering column, cut the wire at the lever, tape your new lever's wire to the old one and then pull it through the column with the old wire. Then just push it in and swap the connectors at the base of the column.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 09-15-2004, 07:51 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Not clear of exactly what your saying.....the lever actually has a wire connector and it doesnt appear to be very long so I dont see how I could pull much thru, its about a 5" long wire with a female connector on it.
As far as the lever is concerned....so your saying it just snaps in....no c-clip or anything else holding it in place?
1991 GMC Jimmy 4x4
Old 09-15-2004, 07:59 AM   #5
RockHQ
ROCKET POWER!
RockHQ's Avatar
Yeah my bad i was thinking of another model. But your lever should just pull out, be careful not to break the end when pulling it though, it's a pain to get out if that happens.
Old 09-15-2004, 08:08 AM   #6
chevychic
chevychic's Avatar
Be careful of just pulling it out. I was just reading some posts about this the other day and everything I read indicated that you have to pull the wheel and remove the plastic cover around the lever. There's a large philip head screw located on the column that you need to be able to get to.
Here's the write up I read that leads me to believe this: http://home.t-online.de/home/O_Scholz/steering.html
Hopefully yours is easier since it's a newer model.
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 09-15-2004, 08:21 AM   #7
RockHQ
ROCKET POWER!
RockHQ's Avatar
Do you mean the "lever screw" (named by that Scholz guy)?
Old 09-15-2004, 06:45 PM   #8
flip66
flip66's Avatar
If I remember right you need to pull the steering wheel but I could be wrong.
flip66 is offline   Reply With Quote
Old 09-15-2004, 06:58 PM   #9
1972C10
1972C10's Avatar
NO Do not remove the steering wheel
You will have to push it in a litlte and then twist it i dont remember wich direction but it pops right out the wire runs trough the colum and connects under the dash
What i advise is get some small wire tie it to the hole in the end of the old cord Put a little black tape on it so it wont get snagged even twist the wire around pull it out and then attach it to the new one the same way Thats how i fished mine down in there.
1972C10 is offline   Reply With Quote
Old 09-15-2004, 06:59 PM   #10
1972C10
1972C10's Avatar
FYI That phillips screw only attachs a lever to the switch itsself the turn signal stalk has a keyway so to speak on it and it removes and looks just like his new one.
