I am assembling a workshop and am interested in knowing what tools you find useful for repairing/restoring your truck, and those you're disappointed in. What comprises a minimal shop. How about a dream shop?
Links to a buying sources would be great if you have them. Thanks! ![]() |
Resident Curmudgeon
![]() Join Date: Dec 1999
Compressor, mig welder, torch, and sawz-all
![]() To me a torch is a necessity. You can't wrench 35 year old rusted bolts
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Still drivin' a Rat Rod
CPNE said what I was gonna say,don't forget an air ratchet,and impact,a good set of wrenches,and sockets.And a good strong garage jack,and jackstands.Nothing worse than trying to work under something and it barely being chest high.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
1969 Custom 30 wrecker
Add a sandblast cabinet to that list. I built my own. The quality of your work will go way up with one of these.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#5 | |
#6 | |
Left Foot Functioning
![]() 10,000 Pound Asymmetric Lift / Wide If you're building a shop, you might want to at least beef up the concrete pad where you would want to put one of these. I've been watching them become more widely available for the past few years. SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
user # 2756
![]() Join Date: Jun 2001
or a parts cleaner. Also, specialty tools- pullers(steering/balancer etc...) a press would be nice.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
buy two sets of wrenches. you will run into alot of bolts that has the same size nuts backing them.
72 long fleet (WIP) ![]() 00 Astro every day ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have big stuff of.....
jack and stands MIG welder torch blast cabinet parts cleaner engine stand engine hoist Caterpillar diesel front end loader for lifting heavy stuff tons of electric tools like grinders, sawz-all, etc....
bob...how did you make your sandblast cabinet???
#11 | |
Mine is about 2' X 2' X 4' but I'm planning on building a larger one this winter with an improved air flow system and the ability to fit at least a cowl panel in.
I've been toying with the idea of putting a "pit" in my garage. I know that I'll never have the money for a lift and there isn't enough ceiling height anyway so I thought of putting in a pit about 4' deep. That way, I can use a rollable stool under it and work with ease.
Should be cheap enough as I'd do all the work myself. Cinderblocks, concrete and maybe some angle iron to go around the opening. Anybody else considering doing one? I'm open for suggestions on the how to.
That's a good idea. I don't see why it would have to be inside the garage either. If I put one outside, I could put it anywhere. Heck, I could occasionally roast a pig in it.
#14 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#15 |
I built a sandblasting cabinet this winter, a MUST for the restorer (tons of little parts that would keep you running back and forth to the sandblasting shop all day). I will never sit there with a wire wheel and sandpaper again... If anyone wants pics or info, just send me a PM. I will be happy to help.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
#16 | |
![]() Actually, I will be building mine right into a wall in my workshop that has a window. I am hoping to design some type of a push fan to blow the dust outside rather than have a noisy shop vac running. (and blowing dust out anyway!) Possibly use a furnace filter over the window??? The dust is incredible with these and is the biggest problem to overcome. I'm still in the planning stages but did aquire 2 large oven racks for the bottom of the work area which will be nice. A tight seal is a must. My old one is lacking in that department and I wear a respirator while using it. (not a bad idea anyway)
#17 |
TIP makes a great build it yourself kit for blast cabinets.
#18 |
i've got to the age that it seems like the 2most important tools in my workshop are the air conditioning system and the refrigerator
#19 | |
#20 |
huh ???
Don't forget a BFH for when your friends bring their ford by to work on it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#21 |
![]() Join Date: Mar 2004
let's see so far i have found these items usefull
grinder air chisle -great for poping ball joints apart and getting ribbits out impact 2 3/8's rachets one with a swivel head 2 sets of open/closed standard wrenches 2 sets of 3/8's standard sockets one short one long ----get 6 sided there stronger extentions 1in 2in 6in + a really long one for reaching odd areas 1/2 to 3/8's adapter - i have found it faster to use this than changing air tools small hammer big hammer 5lbs pliers needle nose pliers wirecutters dentist pick 1/2in sockets 5/8's-1 1/8th 4 jack stands floor jack ziplock baggies permnate marker to mark whats in the bags torch or something to get bolts hot so they come out penetrating oil a bottle of fast orange - abrasive hand cleaner a small hand held sandblaster and a face sheild a computer with a helpfull posting board such as this one engine stand-usefull if your going to build one otherwise don't bother an overhead hoist for lifting engines in and out and lifting off major body parts fabric tow straps for lifting those body parts off -use 2 or 3 set of screwdrivers drill drill bits - save time buy the good ones.....a good set will cost around $200 or about $12-20 a bit a soft plyable air hose - you may have to make one but it's nice to not have to fight it. air compressor ajustable wrenches razor blades air cut off tool -also called a whizzer sawzall and plenty of blades power washer optional but great for cleaning parts body tools: hopefully someone can fill this in i haven't gotten there yet hope this helps, ondrew |
#22 |
Thread chaser set, oil seal driver kit, a decent digital multimeter (Fluke are highend unitis and worth it! IMO) that can give you dwell angle measurements, a decent set of taps & dies.
#23 |
Lovin' Life in Miss.!
lots of lights, lots of 20amp plugs, at least 1 220 outlet,drill press, floor model if you have room bench model otherwise. Bench grinder at least 3/4 horse, equiped with various stones, wire wheels and buff pads. Creeper. Good resperator if you paint/sand blast. Eye protection. At least a 6" vise. Shelving, shelving, shelving. Epoxy coated floor (my GOD it's nice!). Beer fridge, tunes and band-aids. I also have a dedicated shop garbage can. It's nice to rummage around in just dirt for a part/box/label/instruction you screwed up and threw away by mistake.
The truck... you hear that? No really, you did hear that?!!! |
#24 |
Don't buy too small of a MIG like I did. Harbor Frieght has good prices on Ingersoll-rand air tools. thetoolwarehouse.net has good prices on OTC and other brands. My brother runs a Huskey air compressor at his shop, runs it pretty hard and it works well.
'70 K-20 San Diego, CA |
#25 |
I bought a small mig,cause well money is the dictator,but I have a nice arc welder for the big jobs
![]() Also just picked up a tire changer,and stereo with a CD player is a must. And A nice big broad broom.
