09-18-2004, 07:08 PM | #1 |
New Alternator is IN!! Correct tool to tighten it?
FINALLY!! No more flickering headlights and crazy tach! The guy at Kragens said my alternator wasn't bad (he tested it, and it tested the SAME numbers as a brand new alternator), but he said it sounded like the bearing was going out, so he warrantied it, and gave me a shiny new one. I also noticed, however, that the BAT wire going to the alternator was completely broken up on the crimp to the ring terminal. So I cut it back a bit, and crimped on a new ring. With the new alternator in, I warmed it up, got the choke off, and the idle went to 650rpm. So I got out the good ole' voltmeter to test...
1.) Battery read 13.25v+ 2.) Alternator read 12.9v+ This was WITH THE HEADLIGHTS ON, at 650rpm!!! WOO HOO!! I'm ONE HAPPY CAMPER! Also though, what's the CORRECT tool to tighten the alternator? Usually I just use a big pry bar, but it's not doing the job. Isn't there like a special tool, that "cups" the alternator? |
09-19-2004, 03:16 AM | #2 |
yeller
I have always used a pry bar or large screw driver wrapped in a rag...works fine for me.
I think you may need a tool called a "bicep" Tim!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-19-2004, 04:05 AM | #3 |
never fear Jeff, he'll post in 2 days saying it didnt fix his problem, just like he always does.
pry bar should do the job just nicely, every system i've ever worked on without a tensioner got this treatment, and it hasn't failed me yet. |
09-19-2004, 04:12 AM | #4 | |
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
09-19-2004, 04:20 AM | #5 | |
Overworked and Underlaid
ive used a prybar for that everytime ive had to tension the belt on my alternator-in fact i have this like 3 or 4 ft long screwdriver my sisters ex gave me-well i technically stole it lol but i have it for that reason only since it wont fit in my tool box and its too big for the little bit of automotive repair stuff i do.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
09-19-2004, 04:44 AM | #6 |
I use a split rim bar wich is kinda like a round 7/16 dia or so prybar I stick it trou the hole in the upper alternator bracket and pry pushing towards the driver side just make sure its flat up against the case
I have used big flathead screwdrivers in the past |
09-19-2004, 05:33 AM | #7 |
I have muscles AND a big prybar, but it just won't push it STRAIGHT, it just wants to turn crooked and not slide tighter. Seems like it needs a back brace (althoug they never came with one, I know)
09-19-2004, 05:43 AM | #8 |
Ive got a ton of them rear braces
Did you try puttin the pry bar trou the hole in the upper bracket? It puts the push right in the center of the alternator. |
09-19-2004, 05:47 AM | #9 | |
09-19-2004, 05:54 AM | #10 |
Maybe someone has serviced the truck and lost some parts. i keep the bolts just almost tight i just loosen them enuff to where all i have to do is pry the alt and then put a turn or so to snug it down
How loose are the mounting bolts. AND WHY ARE YOU UP AT 5 AM? |
09-20-2004, 10:11 PM | #11 |
ROCKET POWER!
I find it quite amusing your alternator reads less voltage than the battery.
Barely over 13 volts is not good either, headlights on or off. Something's wrong with your truck's wiring. Start off by measuring battery voltage from the poles. Then with the engine off but ignition on measure between the exiting wire (from your ignition switch) and the alternator brackets. Then between the BAT wire and the alt. brackets. Then between the exiting wire and battery negative pole, and then the BAT wire and the battery negative pole. Post the results and i'll bet i can pinpoint your problem.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
09-21-2004, 01:05 AM | #12 | |
09-21-2004, 01:33 AM | #13 |
maybe you could put a smaller pulley on the alt. so that it puts out more a idle.
09-21-2004, 08:21 AM | #14 |
Project 2 Resume
From looking at your website's "And here it is today!" motor pic...Where's the lower alternator spacer, that comes off the head? I see a bolt in the alternator's lower mounting hole, but what is it actually fastened to? That's probably why you took out the alternator's bearing and it cocks when you try to tighten the belt.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
09-21-2004, 01:50 PM | #15 | |
yeller
09-21-2004, 04:07 PM | #16 |
Garage Queen Material
yeap, you need that bracket.
http://www.ocbaud.com/pictures/engine/350side2.jpg |
09-21-2004, 04:53 PM | #17 |
I never seen that bracket when I took the motor out. I was thinking about that though, because it seems like something would be there. But I was looking at it, and it didn't look like that lower hole would line up with the cylinder head. Can I MAKE that spacer thingy, out of a piece of metal tube?
09-21-2004, 04:59 PM | #18 |
you could hit the junkyard and buy them both for cheap.
09-21-2004, 06:16 PM | #19 | |
Signals in the bumper.
I just looked at your cardomain page. It looks like you have a fan...
You got more photos of the vette btw?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
09-21-2004, 07:49 PM | #20 |
Project 2 Resume
I would just go to a junkyard and pickup the whole setup. This way you have everything you need, including the bolt. Then it's done right and if any other problems occur, you can rule that out.
09-21-2004, 08:10 PM | #21 |
Watch out for your cornhole !
I've seen a bunch of them come through the shop with a stack of lugnuts taking up the space after they've left the old bracket on the alternator they turned in for a core sometime in the past.
If you're really trick, use a chrome deep socket as a spacer for the added bling.
09-21-2004, 08:50 PM | #22 |
Hitting up the junkyard is a No-No here, cuz all the yards around here, the trucks BARELY have an engine left in them. Besides that, the yard would probably charge me up the azz for the little thing. I think I'll just do what I did for my power steering pump bracket...use metal tubing to make the spacer. Then, I'll be able to get my belt nice and tight hopefully.
09-22-2004, 12:54 AM | #23 |
Project 2 Resume
Doesn't have to come from a truck. The spacer from any small block with the alternator mounted on rightside (passenger's), accessory holes in the heads and has a long waterpump setup, will work. Personally, don't see the logic of dressing up a motor, only to rig up some sort of spacer. But not my truck, good luck with that. Do you want the measurement of a real spacer, before you make one?
09-22-2004, 01:45 AM | #24 |
You could Make one out of black pipe. say 3/8NPT just cut it down to size and get one long enough that you can cut the threads off both sides.
09-22-2004, 01:48 AM | #25 |
BTW I would sell you one if you cant find one. 10 shipped
