Professional Grade
Driving around town today running some errands, and as I am idling through a parking lot, suddenly my truck starts running rough, and has a hard time accelerating, it goes like normal if I give her plenty of pedal, but otherwise it barely wants to run... If I am just crusing down the road, the exhaust makes all sorts of popping noises and stuff.
Aye, finally thought I'd fixed the thing, now this, lol I guess I'll be parking her till I've got my TPI in...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
mine was doing something kind of the same turns out it was the ignition control module
Tonawanda 454
the module fixed the same problem for me, but i also got a new carb, dist cap, rotor and wires/plugs for it while i was working on it
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
Professional Grade
I guess it won't hurt for me to go to the wrecking yard and get a new module, just to try it...
I've got a new dizzy that'll be going in with the TPI, so that should help a bit too.
Right turn Clyde
If its not that it could be the cam.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Professional Grade
I dunno if it would be the cam... The truck runs too good when I give it some gas for that to be...
I'd also consider the magnetic pickup in the dizzy
Stepsides RULE
bad plug wires if you haven't replaced those, or maybe they rubbed and shorted out? If in drive you here a tick tick tick and the motor stumbles, 1 or more plug wires are shorting on the block, and/or some plugs might be bad? Just throwing some stuff out there.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
Right turn Clyde
Same thing can happen if the valve lash isn't right also. That's why I mentioned the cam if they electrical side of things are good.
Might be crusty spark plugs. My '79 Sub 350 gets buildup on the plugs if I drive it too slow. Every time I go through Austin I have to go 3-5MPH for 45 minutes, & it will barely run for the next 30 miles or so. Same thing just driving slow around town for a few days.
What I drive
Russell,
Start simple, mine did the same thing a few weeks back and I changed the plugs and that fixed it. It needs a full tune up but I am waiting to do that later. Check your plugs, plug wires, dist. cap, rotor button under the cap. ![]()
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
