Old 09-25-2004, 02:47 PM   #1
Trifelynn
Trifelynn's Avatar
Exclamation Is a crossmember worth 50 bucks?
The guy I am buying the blazer from has an automatic crossmember...
The blazer has a three on the tree in it, and the first thing I am going to do is
change it over to a 400 turbo....
just want to know if that crossmember is worth 50 bucks?
thanks
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 09-25-2004, 03:11 PM   #2
Gee_Emm
Alot of people try and sell them for that, I got mine for free. Got any junkyards in your area, might want to check them out first. Don't forget to get the shifter linkages and the pivot point thingy that bolts to the frame
Gee_Emm is offline   Reply With Quote
Old 09-25-2004, 03:14 PM   #3
Trifelynn
Trifelynn's Avatar
pivot point thingy?
Is that a technical term? hehe, j/k
I got an e-mail from a tranny shop, that said that swapping a th350 in for the three speed would be easier than than the th400.... ???
One thing I have never done is tranny work...taking one out, or anything. That is the first thing I am going to have to do.
So, I don't know much about what needs to be done...he has the linkage he is going to give me...but I don't know what you are talking about when you say the pivot point thingy...
Old 09-25-2004, 03:24 PM   #4
Gee_Emm
Kinda hard to explain, it bolts to the frame and the shifter linkage pivots on it. If you are looking to get some better gas mileage out of the truck you might want to consider going with a 200-4r tranny instead. I had a 3 spd in my Jimmy and was going to go with a th350 but I am looking to put a 2004r in because I plan on using the truck as a daily driver. No matter what you go with you will also need to change the flywheel out for a flexplate, and you will need a rad with a tranny cooler.
Old 09-25-2004, 03:39 PM   #5
Trifelynn
Trifelynn's Avatar
Well, this is not going to be as easy of a project as I thought.
I thought it would just be a bolt up procedure.
take the three speed out, and put the th400 in...bolt up the linkage, and
go...but I guess not...
wish there was a guide somewere to show me wth I was doing...
but I guess you never learn unless you do it...right?
Old 09-25-2004, 03:44 PM   #6
Gee_Emm
Thats what I am doing, figuring it out as I go. I am sure there are alot more little things that are needed that I fully havent figured out, like the starter, wiring, carb linkages for a kickdown cable.
Old 09-25-2004, 03:52 PM   #7
pickupman
pickupman's Avatar
Is this a 4wd blazer? If my memory is right on the 4wd the 3pd and auto crossmembers were the same only the 4spd had a little deeper arch to it.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is online now   Reply With Quote
Old 09-25-2004, 03:57 PM   #8
Trifelynn
Trifelynn's Avatar
no, this is a 2wd blazer...
or at least the one I am talking about is.
Old 09-25-2004, 06:03 PM   #9
bad_turbo
turbo enthusiast
bad_turbo's Avatar
you don't have to change the radiator, you can just use an aftermarket trans cooler, probably be easier.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 09-26-2004, 05:35 AM   #10
sdkid
Goin more than that on ebay. My 3spd man was different than an auto. I think there is FAQ on this swap.
sdkid is offline   Reply With Quote
Old 09-26-2004, 06:08 AM   #11
Trifelynn
Trifelynn's Avatar
thank you...
I scanned through the F.A.Q.s and all I found was an "Auto Tranny" Document that I can't open. I PMed the Moderator, and just awaiting a response, then I will go from there....thanks again though
