its all about the +6 inches
Standard and optional equipment listing....1967
This is taken directly from the Restoration catalog for 67. The restoration catalog includes the option book and information that the dealer would have had for you to look at if you were buying back in 1967.
-----------------------STANDARD EQUIPMENT--------------------------- Air Cleaner oiled paper element Axle, Rear ....C/10 Hypoid semi floating type, ratio 3.73; Capacity 3500 lb. Battery 12 volt, 54 plate; Capacity 53 Amp-hr Bodies See Cabs, Bodies & Colors Brakes hydraulic; Self adjusting; Daul System Sizes; front 11' x 2'; rear 11' x 2' Effective Area; drum 276 sq in; lining 167 sq in Brake, Parking Cable to rear wheels; area 83 sq in. Bumper Front only, painted. Carburetor CS10; single barrel down draft. CE10; two barrel downdraft. Clutch CS10: diameter 10"; area 100 sq in. CE10: diameter 11"; area 124 sq in. Cooling CS10: 1 1/4" radiator core, cross flow type;446-sq in area; 13 lb pressure cap. CE10; 1 1/4" radiator core, cross flow type;480-sq in area; 13 lb pressure cap. Controls and instruments; 03, 04, 12, 34 models- Hand choke; light switch; headlight beam control;speedometer;odometer;fuel guage; Lights for generator, oil pressure,engine temperature, brake warning, directional signals and high beam indicator. 02 models- hand choke; light switch; headlight beam control;speedometer;odometer;fuel guage; generator, oil pressure,engine temperature guages; brake warning light (turn signals and high beam indicators included, but not listed) Directional Signals; Class A; 2 front and 2 rear; 2 front and switch only on 02 model. Includes freeway lane-change position onswitch & integral hazzaerd warning switch Engine CS10; 250 Six; positive crankcase ventilation Gross horse power..........155 @ 4200 RPM Net horse power................125 @ 3800 RPM Gross torque, lb-ft.............235 @ 1600 RPM Net torque, lb-ft................220 @ 1600 RPM CE10; 283 V8; positive Crankcase Ventilation Gross Horsepower..........157 @ 4600 RPM Net Horse Power...............145 @ 4400 RPM Gross Torque, lb-ft............275 @ 2400 RPM Net Torque lb-ft................240 @ 2400 RPM Exhaust system; Single pipe & alluminized muffler Filter, Fuel Wire mesh in fuel tank, bronze filter in carburetor Filter, oil CS10: full flow; 1 quatr; throwaway type CE10; Full flow; 1 quart; replaceable element type Frame 39,000-lb-test steel; section modulus 2.98 Fuel Pump Single Action Generator 37 amp Delcotron GVW Plate 5000 lb Lights Head, Parking, tail, stop; intrument panel, Dome on cab models only, backup on pickups. Mirror, Rearview: 03 models; Exterior RH & LH 6 1/4" fixed arm 04 & 34 models; Exterior LH 6 1/4" fixed arm and inside primatic non glare shatterproof 02 & 12 models: none Seat Full-width (except cowl models) Seat belts; Drivers & passenger (except cowl models) includes retractors Shock absorbers Front & rear; piston diameter 1' Springs, front Coil capacity 1250 lb each Springs, rear Coil; capacity 1250 lb each Tank, fuel 04, 34, 03 models,- back of seat in cab, capacity approx 21 gal 02, 12 models-inside of frame at rear; capacity approx 20 gal Tires Five tubeless 8.15-15/4PR front, single rear and spare Tools 2500 lb mechanical jack; wheel wrench Transmission CS10; 3 speed synchromesh; steering column gearshift; ratios 2.94, 1.68, 1.00, 3.14 (rev) CE10; 3 speed fully synchronized; steering column gearshift; ratios 2.85, 1.68, 1.00, 2.9_ (rev) Wheels Five 15" x 5 1/2"; attachment, 6 studs on 5 1/2 inch circle; spare carrier under frame; 4 painted hubcaps Windshield wipers and washers Electric; 2 speed wipers; not included on 02 models That took me 45 min to type out...I'll do the optional equipment later this evening, my neck hurts. Last edited by Longhorn Man; 10-15-2004 at 11:02 PM. |
------------------------------------------OPTIONAL EQUIPMENT---------------------------------------------
K46 Air Cleaner Oil bath; capacity, 1 quart C60 Air Cleaner, Heavy Duty Includes closed positive crankcase ventilationand 1 quart oil-bath pre cleaner; notavailable with 327 engine or on cab chassis models. C60 Air Conditioning, All Weather includes heater and defroster, HD radiator, battery and front springs& 42 amp generator; not avalible on chassis-cowl models Axle, Positraction rear; Capacity 3500 lb G80 Ratio 3.73. Not avalible with overdrive transmission. G80 Ratio 4.11 H01 Axle, Rear Capacity 3500 lb Ratio 3.07; not avalible with automatic or overdrive transmission. H04 Ratio 4.11; included with overdrive transmission. T60 Battery Heavy Duty; 70 amp-hr; included when hd starter motor or air conditioning is ordered. E80 Brackets, Mounting For mounting pick up box; chassis cab models only. J70 Brakes, vacum power Bumper V38 painted rear with painted front bumper only (pickups only) V43 Painted step-type rear (pickups only) V37 Chrome front (pickups & chassis-cabs) V37 Chrome rear (pickups only) P03 Caps hub Chrome P13 Carrier, Spare Wheel Side mounted; pickup models only M01 Clutch HD Diameter 11" for 250 engine with 3 speed overdrive or new process 4 speed transmisions only V05 Coolong, HD Includes HD radiator and extra HD cooling equipment Not avalible with Air Conditioning Z61 Custom Appearance option: Chassis and cab & pickups only; includes bright metal grille moldings, headlight bezels, vent window frames & windshield moldings, control knob trim, horn button cap; color keyed vinyl coated rubber floor mats; custom emblems. Not available with Custom Sport truck option os ordered. Z62 Custom Comfort Option: Chassis and cab & pickups only; includes RH & LH arm rests, RH padded sunshade; cigar lighter; special cowl insulation;full depth foam seat with fabric upholstery; under body coating; vinyl door trim. Not available with Custom Sport truck option is ordered. B98 Custom Side molding: Cab models only; also includes pickup box moldings when ordered on Fleetside pickups only. Z84 Custom Sport truck; Chassis and cab & pickups only; includes bright metal grille moldings, headlight bezels, vent window frames & windshield moldings, control knob trim, pedal trim, horn button cap, chrome front bumper,special CST emblims, vinyl bucket seats with padded centerconsole; carpeting; RH & LH arm rests; RH padded sunshade;cigar lighter; special cowl insulation; under body coating; vinyl door trim Engine L25 292 inline six (CE10 models only); includes 3 speed fully syncronized transmission Gross Horse Power.............170 @ 4000 RPM Net Horse Power................153 @ 3600 RPM Gross Torque Lb-Ft.............275 @ 1600 RPM Net Torque Lb-ft................255 @ 2400 RPM Clutch .............................11";124 sq in Battery.............................61-amp-hr L30 327 V8 (CE models only) Includes HD front springs not avalible with chevrolet 4 speed or overdrive transmission Gross Horse Power.............220 @ 4400 RPM Net horse Power................177 @ 4000 RPM Gross Torque lb ft..............320 @ 2800 RPM Net Torque lb ft.................283 @ 2400 RPM Clutch..............................12" 150 sq in E81 Floor, pickup box Wood with steel skid strips. Fleetside pickup models only. K28 Fuel Filter Equipment Z53 Guages Ammeter, engine temp, oil pressure, not avalible on chassis cowl models, included when tachometer is ordered Generator K79 12 - 42 amp Delcron K76 5 - 61 amp Delcron K81 23 - 62 amp Delcron Glass, soft ray A11 Windshield only not avalible on chassis-cowls A11 All windows, not avalible on chassis-cowls K19 GM Air Injection reactor Aproved by the State of California for vehicle registration. Requires Closed Engine Positive Crankcase Ventilation K37 Governor 250 engine; 1800 - 3000 RPM 2800 - 4000 RPM 292 engine 2200 - 3100 RPM 2800 - 3900 RPM 283 engine (Not avalible with GM Air Injection reactor) 2400 - 3600 RPM 3000 - 3800 RPM A85 Harness, Shoulder Driver and passenger, not avalible on cowl models or with optional bostrom seats. C42 Heater & Defroster Delux Air CROSSED OUT...NOW STANDARD V76 Hooks, Towing Two, front, not avalible with chrome bumper U01 Lamps, marker Five, not available on cowl models A97 Lock Side wheel carrier, pickup models only Mirror, Exterior D48 front cross view 8" diameter D32 RH 6 1/4 " fixed arm, pickups only D32 RH 17 1/4" swinging arm, pickups only D32 LH 17 1/4" swinging arm, pickups only D32 RH & LH swinging arm chassis cabs only West Coast Jr type 6" x 11" D29 LH only, pickup models only D32 RH & LH (pickups and chassis cabs) West Coast Sr type, 7" x 16" D30 LH only, pickup models only D30 RH & LH pickups and chassis cab Z81 Custom Camper Nameplate Chassis cab and pickup only MINIMUM requirements are front stabilizer bar, HD rear shock absorbers, HD rear springs or Aux rear springs, 7.00-15/6PR or 6.50-16/6PR tires Paint, Exterior See cabs, bodies,& colors section K26 Pump Fuel & Vacuum Booster; CS10702 model only V01 Radiator Heavy Duty Included when 327 engine with automatic transmission or A/C or HD coolinf is ordered U63 Radio Pushbutton control, not avalible on chassis cowl. Seat for cab models only, not avalible when custom sport option is ordered A55 Bostrom "Viking" driver seat only A55 Bostrom "Viking" driver seat plus 2 man companion seat Z52 Full-depth foam included when Custom Comfort is ordered A50 Bucket, driver & passenger, includes carpeting and padded center console Z55K Serial Number Plate (state of Pennsylvania) 2000 pound rear spring required Shock Absorbers HD F51 Front and rear G65 Rear only U15 Speed Warning Indicator Not avalable on 02 models G60 Springs, Aux Rear Capacity, 5000 pounds each F60 Springs, Front Capacity 1350 lb each, included when 327 or A/C is ordered G50 Springs, Rear Capacity, 2000 lb each F59 Stabilizer bar, front suspention K67 Starter Motor, HD Includes HD battery N40 Steering power Not avalible with A/C or HD cooling when 292 & automatic transmission are ordered U16 Tachometer Electric includes optional guages, not avalible on chassis cowls K31 Throttle Control Manual Transmission M10 Overdrive, includes 4.11 rear axle ratio, Not available with 327 or govenor equipment M35 Powerglide, not available with govenor equipment M49 Turbo Hydra Matic M17 Chevrolet 3 speed fully synchronized with 250 only. M20 Chevrolet 4 speed synchromesh, includes 11" clutch, not avalible with 327 engine M28 New process 435CR 4 speed close ratio K24 Ventilation, Closed Engine Positive P01 Wheel covers, full Bright metal, avalible only with 15" wheels A10 Window, Full-View Rear Chassis-cab & pickup models only Last edited by Longhorn Man; 09-27-2004 at 11:49 PM. |
