Old 09-29-2004, 05:59 PM   #1
Trifelynn
Trifelynn's Avatar
Anybody here bagged a blazer?
I guess with my project(71 2wd blazer), I am going to start with the chassis...
which includes bags
I was wondering if I have to do a C-Notch?
If so...how do I make it so that the back seats still fit and what-not...
any help would be great...maybe even a few pics
thanks guys
Lenny
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 09-29-2004, 06:19 PM   #2
Alexis
Member since 2000
Alexis's Avatar
contact brad2 , he's got a sweet 2wd in the works.
Alexis is offline   Reply With Quote
Old 09-29-2004, 06:57 PM   #3
grnddwn
belly dragger
grnddwn's Avatar
Yes you have to notch it if you want it to sit low, but I've built my notch and tub so it will fit under my back seat
grnddwn is offline   Reply With Quote
Old 09-29-2004, 10:42 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
grnddwn,... do you have any frame shots of your blazer? Front and rear. Cool ride,.... thanks. Lolife99.
Keith
Convert to disc brakes.
Old 09-30-2004, 09:01 AM   #5
Trifelynn
Trifelynn's Avatar
Yeah, I would like to see a picture, if you can...
so, I can see what it looks like.
how much head room do you lose with the seats?
I figured you would have to cut the bed floor, and make it a little higher to cover the notch
Old 09-30-2004, 12:04 PM   #6
MrShelley
Too Many Clubs Club
MrShelley's Avatar
This Blazer isn't even C-notched in the rear and it sits nice and low.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 09-30-2004, 01:28 PM   #7
Trifelynn
Trifelynn's Avatar
So, if it is not notched...then how did you get it so low?
From what I understood, you had to notch so that it wouldn't rub when you
let all the air out....
I am just trying to figure out the best way to lower it...
I know I want bags...because from what I know that is the ride quality is the best....
Old 09-30-2004, 09:15 PM   #8
MrShelley
Too Many Clubs Club
MrShelley's Avatar
It's not my Blazer, simply one I saw at Super Chevy. I snuck a peek under it to look at the bag set-up, and noticed it wasn't notched. I was also surprised that it sat so low without a notch.
Old 10-01-2004, 12:09 PM   #9
raggedjim
raggedjim's Avatar
Trife, I just found a new website called webrodder.com that has some great tech articles. One is an Airride suspension swap on a c10 that should help with your blazer.
You have to join to get in but the tech articles are worth the trouble.
Rg
raggedjim is offline   Reply With Quote
Old 10-01-2004, 03:16 PM   #10
Trifelynn
Trifelynn's Avatar
thanks a bunch...
I am trying to break all my projects down...and frame, and suspension
are first...so, I just want to know what I am doing, before I get started....
gonna start taking everything off the frame in the next week or so...then the frame work is happening...
thanks for all the help
Old 10-03-2004, 08:00 PM   #11
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Here's a pic of the axle/frame area on the Blazer I posted before. Notice how low the truck sits even without a notch.
Old 10-03-2004, 08:50 PM   #12
lolife99
lolife99's Avatar
My blazer has about that much room also,... and mine bounces off the snubbers on most hard dips in the road. I really don't want to notch it, either. I have ECE's shock reloctors, shocks, adjustable panhard bar, and 6" drop springs. Does that blazer have bags or coils? Hard to tell in the pic.
Keith
Old 10-03-2004, 09:23 PM   #13
Trifelynn
Trifelynn's Avatar
Yeah, that definitely looks good...
I really didnt want to notch, if I didn't have to, and I am told
not to get that bolt in kit <shrug> I don't see why not, but oh well
Old 10-03-2004, 09:39 PM   #14
MrShelley
Too Many Clubs Club
MrShelley's Avatar
The Blazer in the pic is bagged. Sorry the pic isn't better, but it was hard to get under it since it was so low.
Old 04-03-2005, 08:13 AM   #15
shifty
Questionable
shifty's Avatar
Classic Chevy C-10 Upgrades - Part 1
Installing new disc brakes, dropped spindles and air suspension in the front of the 1963-72 Chevy C-10
Classic Chevy C-10 Upgrades - Part 2
Rear air suspension and plumbing suggestions for the 1960-72 GM trucks
Six Pack to GO - Part 5
Rebuilding the front suspension for the 6-pack and all other 1963-72 GM trucks
Some other articles:
http://webrodder.com/index.php?searc...Stories&CID=11
http://webrodder.com/article.php?AID=42&SID=60
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-03-2005, 04:40 PM   #16
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I did CCPs bolt in notch and it was very simple. I personnelly wouldn't lower with out a notch. But I had mine bagged in the rear prior to the notch. I didn't like it. I wanted to drive with it at the height that it sat when the rear axle housing was sitting against the frame. But thats the beauty of these trailing arm trucks, so easy to throw the coils and bolt bags in and see how you like it. Then you can always notch later. But don't screw up like I did and get firestone bags they don't compress as low and lift as high as Slam Specialties or airlift bags.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 04-03-2005, 05:50 PM   #17
72BLAZERDUDE
72BLAZERDUDE's Avatar
We used the bolt-in notch (99.00) from CPP on my sons 71 and it was very easy. Quality and fit was great. I guess if you were worried about it weld it in after. Now we did have the bed off so that did make access much easier but I think it shouldn't be to hard on my Blazer. Just have to be a little more creative on using the grinder. I think with bags you almost have to notch it. I am doing mine in 2 weeks. so I will keep you posted.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 04-03-2005, 06:11 PM   #18
BIG_BLAZER86
BIG_BLAZER86's Avatar
n2tRUX WHAT SIZE ARE THOSE RIMS,I have a 78 2wd blazer and I'm putting 24" rims on it. I plan on a 8" c notch in the rear and Zing the frame in the front. Hopefuly I'll be starting that project here soon, will post pictures as soon as I do.
81 blazer 2wd tukin 30's
07 Jeep Grand Cherokee on 26's
Tube chassis 5.3,dual T cases,54" boggers,steering rocks
Dodge 3500 with some mods
BIG_BLAZER86 is offline   Reply With Quote
Old 04-03-2005, 07:16 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by BIG_BLAZER86
n2tRUX WHAT SIZE ARE THOSE RIMS....
Those are 20's in that pic. They have been sold though. If I ever get this thing finished it will be rolling on 22's. The rear floor will be raised a bit so I don't have to have a huge hump for a bridge. It won't be laying rocker, but it will be close enough to make me happy....
This is how the front will sit.....
