700R4 swap
What parts do I need to swap a 700R4 transmission in place of a 69 TH350 on a 69 small block? As I understand it, the 700R4 will bolt in place of the th350 and use the same yoke, I just may need to move the crossmember a little. I guess the 700R4 is only 1/16 or 1/8 inch longer than a th350 with a long tailshaft, so I won't need a different drive shaft? Do I need different shifter linkage? What years had the mechanical speedometer cable? I've been told 700r4's from 4x4's are stronger than other 700r4's but they are the same dimensions, is that true? Should I only look for fullsize truck transmissions or are camaro/firebird/s10 tranmissions ok too? How much should I expect to pay for a working 700r4? I know that's a lot of questions, but it seems like a lot of people do this swap, I just wonder how difficult it is.
-Guff 1969 C10 LWB, 350, 700R4, 3.73 gears |
I am pretty sure the 700r4 is 1 3/4 inches longer and you will have to shorten the driveshaft. I have a 700r4 from an 86 IROC and it has a mechanical speedo. Not sure what years have it after that though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The 9 inch Turbo 350 is the same length as the 700r4 is . I've swapped a bunch of them around. Yoke and driveshaft will reuse directly
On my old trucks, I reuse the stock linkage. Only difference is that it won't pull all the way down into 1st gear with the shift lever. I use van 700r4s usually, because they kept the mechanical cable speedometer much later than pickups did. Be sure and get the TV cable geometry and adjustment dialed in properly so you don't melt your overdrive tranny down.
Thanks Tx, what other parts will I need if any? Isn't there a wiring plug for controlling torque converter lockup? Also, what kind of bracket(s) do I need for the tv cable. My kickdown cable is currently unhooked because the PO put on an edelbrock intake but didn't get the kickdown bracket.
Great topic! I will be approaching this obstacle here soon too.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Lovin' Life in Miss.!
http://207.44.196.117/vboard/showthread.php3?t=33266 Here's something from the FAQ's. I used the tv cable kit from www.700r4.com , but it is not necessary. I've got the install done but need to play some more with the tv cable....it hunts real bad between 3rd and 4th on part throttle.
The truck... you hear that? No really, you did hear that?!!! |
Forget the Cameros and Firebirds unless you want to change the tail shaft.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
C10 Club Tennessee
How about late 80's-early 90's Caprice's?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: Sep 2001
I was thinking that you need to stay below '86 or so to avoid computers. BTW, I have to change my yoke in switching from a 3speed to the 700r4. New tranny has 30 teeth, old had 8. The drive shaft will have to be shortened 1.5 inches or so, and that's with my engine in the forward position.
#10 | |
Look in Vans and Suburbans for your new trans. They used cable type speedometers much later than pickup trucks did. No computer controlled 700R4 transmissions until 1992 or 93, depending on application. Then, it was called a 4L60E and has a huge wiring harness that plugs into the transmission.
You will need the metric bolts for such items as the torque converter, trans mount to tail housing and nut for linkage stud.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
On the road
![]() ![]() Join Date: Jan 2004
Great topic. Even if you have a trans with the elect speedo you can swap out the parts from an older 700R4 with a mechanical speedo and make it work. I saw a thread on here or somewhere about it. To enable shifting into all of the gears all you have to do is check where the rod coming from the column attaches into the cross shaft and drill another hole about a 1/2" closer to the selector shaft and attach your rod into it. This changes the geometry (the angle of the dangle) and will give you more swing with your shifter and you can get all the gears. If you have an older 700R4 with the rear mount cast into the tailshaft housing you can use the turbo 400 position to mount your rear crossmember. Most of the later 700's have the mount in the trans case directly behind the pan and you will have to drill new holes in the frame using this mount.Hope this helps.
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
hold the phone on not hooking up the tv cable, it controls the amount of pressure to the plates and clutches- not hooking it up or not getting it right will cause a really early departure of trans. also there is the matter of the lockup torque converter if not wired up it will not lockup in od which also kills it because it will not cool enough! thats a quote from my trans expert friend! you can get the parts to make it lockup cheaply or buy the kit for around $70
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
#14 | |
#15 |
its all about the +6 inches
There is quite a bit written in the FAQ on this topic...more in detail than listed on this thread...and some links with real good reading. Enough to keep you ocupied for the rest of the evening.
#16 |
GSFMECH,
Good one on drilling the hole for the selector 1/2" up from the original spot to allow shifting down into 1st gear. I've been reading for weeks, but I've not heard a solution for that yet.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
#17 |
TOTY 2006
![]() Join Date: Dec 1999
Just wondering if anyone has had any trouble with the 700r4 tranny hitting the flange at the bottom of the cab firewall? I did a test fit, and my cab was sitting on the tranny. Looked to be about 1/2 inch too high.
#18 |
I have heard about someone else having that problem with the firewall hittting the tranny. Is you Motor in the 6 CYL position ? I think that's where you run into the problem or mabye just the odd cab was built a little bit diffirent.
How is your truck coming along ? Later , Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#19 |
is it a big block engine in a small block truck? How are the cab mounts?
#20 |
![]() Join Date: Apr 2000
I but a BB and a 700R4 in a low hump cab and have lots of room.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#21 |
Which towers did you use, the 67 - 71, or the 72 towers...did you use the tranny mount spacer that keeps the drive shaft geomitry in line, or did you mount it directly to the cross member. Was it a 1/2 ton 2 wheel drive, or something else?
Lots of variables in the big block fitting in a low hump cab. |
#22 | |
#23 |
Its a 1/2 ton LWB with coils. Used 72 mounts. And useda turbo 350 trans mount I think. No real problems. Used original cross member just muved it a little and drilled new holes. As fare as im concerned its a streight bolt in.
#24 | ||
#25 |
I've used 67-71 mounts on mine with plenty of room. Every truck I've ever owned has been a small hump truck. There is plenty of room even with a 700R4.
If it's hitting, you need to look at replacing your cab mounts. When I first put my 454 into my low hump truck I have now, it hit the bottom of the cab. New cab mounts raised it right up. Now, I can slide my hand between the trans and cab in all spots. Yes, I run the trans mount spacer too.
