10-01-2004, 03:37 AM | #1 |
Repairing my returned stolen truck
I have a 1979 4WD Chevy 350/350turbo that I recently recovered. (It was stolen 2 years ago.) I am trying to put wires back together under the hood. My question,The wire in the bottom left hand corner coming out of the fuse box,does it go to my fuel tank(s). If so, what wires feed the volts guage? Thanks for any help I can get.
Freebird41 |
10-01-2004, 11:50 AM | #2 |
I'm back with 2nd truck!
What color wires are they?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
10-01-2004, 03:52 PM | #3 |
I believe it to be pink,not sure. The oil sending unit is right beside it.As far as the alternator guage,the little wire is still hooked up but I dont know which wire goes with it in the 2 wire plug-in. Thanks
10-01-2004, 06:26 PM | #4 |
the pink wire on my truck is the 12v wire for my distributor.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
10-01-2004, 09:35 PM | #5 |
Tonawanda 454
what did they do? trash the wires? tear out the engine without disconnecting anything? sounds nasty
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
10-02-2004, 12:03 AM | #6 |
Just tore up the wires and the steering column. I now have that problem fixed BUT,the lights are now not working. Blowing bulbs and turn signal and bright light indicator comes on with dash lights. Maybe a bad ground......
10-02-2004, 12:08 AM | #7 |
Professional Grade
Just so you know -- GM used the positive terminal as the common pole on the dash bezels, not negative, make sure you wired it up accordingly...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-02-2004, 09:04 PM | #8 |
Russell,
Thanks for the response. None of the under dash wires were damaged. Just in the column,which I replaced and the wires under the hood. The alternator,starter,and main red wires. I now have the fuel guage,alternator and other guages wired right ,BUT..., when I turn on the headlights the turn signal and bright light indicator comes on with the dashlights. My left front signal bulb blowed and the headlights quit working. Any advice would be very much appreciated. Freebird41 |
