Old 10-01-2004, 08:55 PM   #1
elmono
3.73 to 4.10 w/ traction
I'd like to change out my front and rear diffs to posi/locker including a gear change. Any ideas? Currently running 8.5 10 bolt with 3.73. Economically, 14 bolt, D60, or air lockers aren't feasible at the moment. Thanks, Chad.
1985 GMC K1500 350 700r4 NP208 3.73
elmono is offline   Reply With Quote
Old 10-02-2004, 10:12 AM   #2
cochino12
It followed me home?
cochino12's Avatar
i have a used detroit tru trac for sale if you are interested.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-02-2004, 10:40 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Be thankful you have 3.73s, my 85 K5 had 3.08s! Anyway what size tires you going to run? That and off road use need to be factored into whether a good tight limited slip or locker is need for the rear. Since you'll have the diffs apart go with units that replace the open diff carrier(vice lunch box lockers).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-02-2004, 10:49 AM   #4
elmono
I just added 35" BFG's and that's why I want to move to 4.10 gears. I'm on pavement the majority of the time and the offroading I do is mud, sand, etc., but no rock crawling or Moab-type stuff. I do occasionally have a boat behind me as well. So I guess I'm leaning towards a front and rear setup with good street manners, but the ability to get me out of a sticky situation when necessary. Thanks for the help, Chad.
Old 10-02-2004, 10:58 AM   #5
elmono
cochino12
What's your True trac gear ratio? Also, how much? Shipping? What was it used in? What shape is it in? Thanks, Chad.
Old 10-07-2004, 11:50 AM   #6
elmono
Maybe I should jump up to 4.56 or 4.88? Any ideas? Thanks, Chad.
Old 10-07-2004, 01:28 PM   #7
cochino12
cochino12's Avatar
The guy I bought it from was using w/4:10 so it should work with 4:10 ^ I think. It was in a K5 and looks to be in excellent condition. I will try and get some pics for you, my comp. at home is not working so It might take a few days. Asking $150 + mail
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
