10-02-2004, 02:12 PM | #1 |
"The dude abides"
Th700-r4
I have kind of looked through the old posts on shift kits and such and I think that I have come to the conclusion that the Trans Go is the way to go. I was just curious as to they have a shift kit and a reprogramming kit. (or something like that)
I believe that the shift kit can be done with the transmission in the vehicle. Can the other kit be installed this way also? I really don't feel like pulling the transmission again. Especially with the transfer case attached to it. I am looking for a kit that will change my 2-3 shift. My transmission shifts too early in 2-3 right now and then I would like it to change the lockup on the converter if possible. Right now the 1-2 is nice. The shift point is right. 2-3 shifts before the engine revs enough causing it to bog down. (Approximately 35MPH for the 2-3 shift.) Just after that shift you can feel the converter lock up which bogs it down even more. Especially when towing. When towing the shift points are raised slightly, but it still shifts too early. At WOT 1-2 is nice. 2-3 shifts before it can rev well. I don't have a tach, but I would guess that the RPM's are maybe at around 4000 to 4500 when it shifts from 2-3 at WOT. Anything other then WOT, it shifts sooner. The shift 1-2 is nice and firm. 2-3 isn't as firm though. I don't mind firm shifts, I just don't want harsh shifts. I think that I have pretty much made up my mind with Trans Go, just curious as to what I should get to fit my needs/wants.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
10-02-2004, 03:18 PM | #2 |
Right turn Clyde
You can taylor the shift kit to what to want as far as firmness. But I dont think you are going to be able to just adjust the 2nd gear shift point. I think the shift points will all be higher or low and you have to deal with the governor for that. You can install the shiftkit with the transmission in its just harder.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
10-02-2004, 05:12 PM | #3 |
hay you cant you just put in a corvette servo in it to make it shift harder
10-02-2004, 06:16 PM | #4 |
Stepsides RULE
the 700R4 doesn't have the little module that you can adjust the shift point with? I'm pretty sure the TH350 and 400 have a little module you can adjust the hardness of the tranny, but i don't think its wise to play with it
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
10-03-2004, 05:48 AM | #5 |
The harder the shift..............the more pressure is put on the trans. pump and it's seal that likes to blow out.
10-03-2004, 08:46 AM | #6 |
Check out www.700r4.com and www.transmissioncenter.net. They have a lot of useful info on Chevy Overdrive transmissions....
10-03-2004, 03:44 PM | #7 |
BAD BOW-Silverado XST
Here is a link for a 700R4 5000 RPM governor.
http://home.earthlink.net/~micfly/gov.htm |
