1990 chevy won't start after running
hello,
I have a 1990 chevy, with TBI that won't start up after running 10 minutes or longer. there is no fuel comming out of the injectors while the engine is turning over. a quck blast of starting fluid and she runs fine. Any body have any idea's I suspect a sensor some where. Thanks Mike
Mike K Friend of Bill W |
did you check for fault codes?
is your fuel filter good? did you check the fuel pump for proper operation and correct pressure? |
change your ingition module...the injector signal is sent thru it...could also be your fuel pump or the fuel pump relay
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
Thanks,
In the future I will try to post these in the correct group. thanks again.
