Old 10-03-2004, 11:57 AM   #1
desertchevy
hood sticking
I have a 85 suburban and the hood does not pop up when I pull on the cable, I have to go out and smack the top of the hood and it pops up. I want to buy a new steel cowl hood but I'm no tgoing to spend that kind of money just to have to go out and hit it to open the hood. I had a 90 that did the same thing. I tried to adjust it but there is not much of an adjustment. Do I need a new cable and latch or what? Any help would be great. Thanks
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
Old 10-03-2004, 12:07 PM   #2
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
try oiling it up real good, just maybe sticking, i have seen it happen on lots of cars & trucks
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 10-03-2004, 04:58 PM   #3
somery
it very well may simply be the adjustment. especially if you got a burban the hood is totally adjustable to go as far as not closing at all. it is too far back or to close to the front. check the margin if they are the same on both sides check the front to see if it is exactly the same as the fender on both sides. this is all only if you already tried the last post of lubing up the hood latch on the truck itself. im 90% sure its adjustment if all of the latch springs are there and its lubed. i like the hanging up hood tho, cause thats how you open the hood of a beast!! there are a lot of bolts on the overlapping hinges on each side..you need a helper to hold up the other side while you only loosen the bolts (okok overexplaining i know ...hmmmm)
somery is offline   Reply With Quote
