Old 10-04-2004, 11:55 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
Are these necessary?
stainless steel exhaust flex joints, if you have a high performance motor should you consider putting these on? are they worth getting?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-05-2004, 12:05 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If your exhaust is hung from the frame with rubber isolators, then these are not needed. They may help a little if your pipes are secured real tight, but they are a PITA when they rust out after 5years or so, even though the rest of the exhaust is fine.
Old 10-05-2004, 12:19 AM   #3
1972C10
1972C10's Avatar
I just get my pipes welded straight to the headers and dont worry about it.
High performance motor has nothing to do with leaks its weak motor mounts. I run solids and dont have leaks Before i went to solid i would have to change gaskets every few months Now gaskets last untill i pull the headers.
1972C10 is offline   Reply With Quote
Old 10-05-2004, 12:38 AM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i put one of those on my straight 6 cause i kept going thought exhaust doughnuts. it helped. but i dont have them on the V8 now.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
