10-05-2004, 01:16 PM | #1 |
Its Magically Delicious
Radiator swap tips
Radiators leaking ..... so time to swap
This looks like a pretty straight forward job to me ... i hope the tranny cooler lines dont give me any problems .... any tips or suggestions for tackling this job ... thanks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
10-05-2004, 02:12 PM | #2 |
Watch out for your cornhole !
it's as easy as it looks
10-05-2004, 02:19 PM | #3 |
"Ochre Ogre"
You are right, the tranny cooler lines are your only concern. They are usually rusted to the line and twist instead of turning out. Probably not a concern for you in Oregon. For a quicky job I use a pipe cutter and splice in a rubber hose.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
10-05-2004, 02:29 PM | #4 |
Sometiems tranny cooler lines are stuck You might spray them with penetrating blaster or wd-40
And use a flare wrench or a open end snap on or other good wrench. Ive seen too many of them stripped out from people using cheap-o 1/2 open end wrenchs. |
10-05-2004, 02:31 PM | #5 |
I did mine and it is pretty easy. Just make sure you get all of the water out.
10-05-2004, 02:34 PM | #6 |
of what skokie ??
10-05-2004, 02:38 PM | #7 |
Of the radiator. I left that part out.
10-05-2004, 02:49 PM | #8 |
Definitely use a flare/line wrench. Don't use the a vise grip (like previous owner of my green truck) unless it is the last resort......lol
Make sure the rubber supports are in good shape. You don't want you new radiator rubbing metal to metal. Don't over torque the clamps on the radiator and crush the pipe. All I can think of for now...... |
10-05-2004, 04:51 PM | #9 |
after replacing fill it up with water and check for leaks, after you make sure there's no leak drain and fill with 50% antifreeze solution
10-05-2004, 04:55 PM | #10 |
its all about the +6 inches
If your tranny cooler lines are stuck, you can heat them with a torch, a propain one will help, but won't work as well as a real one would.
